The Stop button blinks to let you know Loop mode is active, it's not
supposed to stop the pattern or bring up the Loop screen. You can go into
the Pattern Edit menus and change the Loop settings there, or use the
shortcut keys (Tap+Select, Tap+Edit) to set the loop points manually.
drewaight1 <drewaight@...>
04/20/2003 05:55 PM
Please respond to xl7
cc:
Subject: [xl7] does anyone else's loop mode not work?
Upgraded to OS 2.0 when I hold down the Tap button and push stop, the
stop button blinks red but the pattern neither stops nor does the
display show the loop function screen. What am I doing wrong?
