Re: [xl7 Recording audition grooves
2003-04-19 by sounddaddy@comcast.net
Can I record audition grooves to a track ?
  Sent: Saturday, April 19, 2003 10:42 AM
  Subject: [xl7] Master FX settings question
  I'm trying to get my head around the FX section - mainly the master
  FX. Am I right in thinking that 'master FX' are saved with a pattern?
  So whenever a pattern is recalled, the FX will always change to
  whatever the settings were when that pattern was saved?
  Is there any way to override this - so if I recall a multisetup then
  it's FX will override any future pattern changes?
  Maybe I'm gettig confused. I have this song 'constructed' and I
  wanted to add some reverb without having to change every single
  pattern that the song uses. Is that possible?
  Would it be better to use a single preset to control the FX?
  Any help much appreciated!
  drs2k
        Yahoo! Groups Sponsor
Re: [xl7] Re: [xl7 Recording audition grooves
2003-04-21 by erik_magrini@Baxter.com
Yes, connect the midi out to the midi in of the XL-7 and record while you
press audition.
2003-04-21 by sounddaddy@comcast.net
Thank You My Brother ... I knew I heard that before ... Thanks again !!!
  Sent: Monday, April 21, 2003 7:26 AM
  Subject: Re: [xl7] Re: [xl7 Recording audition grooves
  press audition.
