spontaneous pattern switching possible?
2001-08-05 by Eric
I browsed the online manual looking for the ability to switch patterns spontaneously, but found no implication of it. I'm considering switching from the yamaha rm1x which does have this feature, but without this feature I won't want to. It works by having the 16 buttons switched to "section" mode in which each button is assigned to starting a pattern (made up of 16 tracks), with the option of switching being quantized to beat one. This allows one not to be locked into a predetermined song arrangement, jam over a groove as long as you want, switch to a break, start another section, etc. Switching is also controllable with a yamaha foot controller (mfc10), but more ideally each of the 16 pattern/section switching should be controllable by say a midi cc# so any midifoot pedal could be used. If this is not capable on the xl-7, what is the likelihood it could be incorporated in an os update?
