RE: [xl7] Re: OS 2.5 ideas
2003-03-16 by Andre Lewis
Yeah I have to admit I am addicted to that feature on the 777
Sent: Tuesday, April 15, 2003 6:46 PM
Subject: [xl7] Re: OS 2.5 ideas
One more time.......last time I promise
Making holding notes easier in GRID or STEP RECORD mode .
GRID:If you want a note to hold say from note 3 to 4 press and hold
three then hit 4.From note 3 to 16 press and hold three and hit 16
all the notes from 3 - 16 will be tied together, say for a long bass
sound. This is how the future retro 777 sequencer is. It is simple
and that is good. You dont have to mess with gate times for an easy
result.
STEP: Even the MC-505 is better in this sense you just add a note
then press "tie" for how many times you want the notes to hold. So if
you want it to hold from note 1-5 .. add a note on note 1 then
press "tie" four times ,simple and effective.
Re: [xl7] OS 2.5 ideas
2003-04-14 by Mike Capoizzoli
OS 2.5 suggestion... How about a COPY/APPEND to function which would
let you "copy a patten to itself making it twice as long" or "append it
to another pattern" making the 2 patterns 1 NEW pattern.
Sequential had this function in their Drumtraks Box in the 80's... I
Liked it !
MCap
Date: Monday, April 14, 2003 11:34 am
Subject: [xl7] OS 2.5 ideas and bug fixes?  :)
> <span><p><span><p>
> <tt>
> New OS ideas:
> - Pressing Play+Stop will automatically cause the Pattern to begin
> playing
> back at the start of any defined Loops.  If no loop points are
> defined,
> then the Pattern begins playing back at the beginning as normal,
> or
> switches to the next queued pattern.
> - Track Mute buttons should function as shortcut keys for Pattern
> Edit
> menus, same as they do within Preset Edit.  True, there's no
> labels
> screened on the box for this, but the most common used ones will
> be easy
> enough to remember after you've done it a few times..
> - Cut, Copy, and Paste commands and Note and Event List Edit
> screens
> should default to the current active (Basic) Track.  Ditto for the
> Send
> screen in the Global menu.
> - TAP+ (Pattern Edit button) becomes shortcut for Revert to Saved.
> - TAP + (Preset Edit Button) loads the initialized Preset to the
> current
> Track (basically this is a way to initialize the current preset).
> - TAP + Arp button acts as short cut for Arp hold On/Off.
> - Snap and/or Relative mode for the 16 knobs.
> - A Copy and Paste field command.  IE, pressing some button
> combination
> will cause the value currently selected by the blinking cursor
> location to
> be copied.  Another button combination causes this value to be
> pasted into
> the next selected location of the same value type.  This would
> make it
> easy to set things (Note #, CC#, etc) to the same values while in
> the List
> Editors, or in any screen for that matter.
> - An option (selected or disabled via the menu) for Multisetups to
> restore
> ALL parameters, including current Pattern location, basic channel,
> etc.
> - The ability to grid record CC numbers.
> Bug fixes.
> - Currently if your cursor is on the count in field of the Record
> Armed
> page, and you scroll hard to change this to the 'note symbol' used
> in
> first note record, the cursor will jump to the quantize field by
> itself.
> - Issue with the Repeat Button unmuting tracks.
> - Changing meters on the Conductor Track in Song Mode causes a
> complete
> lock up.
> rEalm
> </tt>
> <!-- |**|begin egp html banner|**| -->
> <table border=0 cellspacing=0 cellpadding=2>
> <tr bgcolor=#FFFFCC>
> <td align=center><font size="-1" color=#003399><b>Yahoo! Groups
> Sponsor</b></font></td></tr>
> <tr bgcolor=#FFFFFF>
> <td align=center width=470><img
src="http://us.a1.yimg.com/us.yimg.com/a/sl/sleepangel/sleep_300x250.gif
" alt="" width="300" height="250" border="0"></td></tr><tr><td><img
alt="" width=1 height=1 src="http://us.adserver.yahoo.com/l?
M=249982.3083889.4452939.1728375/D=egroupmail/S=:HM/A=1524963/rand=31858
6944"></td></tr></table><!-- |**|end egp html banner|**| -->
> <tt>
> </tt>
> <tt>Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.</tt></br>
> </span></span>
2003-04-14 by erik_magrini@Baxter.com
OS 2.5 suggestion... How about a COPY/APPEND to function which would let
>>>You can do this now in the Pattern Edit menu, it's called "Extend
Sequence Data To:".  This lets you take a smaller pattern, and then copy
itself until the Pattern length you specify.  Page 80 in the manual. <<<
or "append it to another pattern" making the 2 patterns 1 NEW pattern.
>>>Cool idea! <<<
2003-04-14 by A.Ruesberg
you can append a pattern to itself using the "extend sequence data to"
function.
appending to patterns would be really nice.
alexander
Am Montag, 14.04.03 um 17:54 Uhr schrieb Mike Capoizzoli:
> Liked it !
> MCap
> From: erik_magrini@...
>> <span><p><span><p>
>> <tt>
>> New OS ideas:
>> playing
>> defined,
>> or
>> Edit
>> labels
>> be easy
>> screens
>> Send
>> current
>> combination
>> location to
>> pasted into
>> make it
>> the List
>> restore
>> etc.
>> Bug fixes.
>> Armed
>> in
>> itself.
>> complete
>> lock up.
>> rEalm
>> </tt>
> rand=31858
>> <tt>
>> </tt>
>> Service.</tt></br>
>> </span></span>
> Get a FREE REFINANCE QUOTE - click here!
> http://us.click.yahoo.com/2CXtTB/ca0FAA/i5gGAA/pWZylB/TM
2003-04-14 by Aaron Eppolito
As someone already pointed out, this is what "extend" does.
If you don't mess with your routing (i.e. you leave track 1 to channel
1, etc) you can do this with Combine and Explode.
Step 1: Source pattern (the one to be played first): Combine all
tracks.
Step 2: Destination pattern: shift all tracks right by the length of
the pattern to be played first.
Step 3: Destination Pattern: Explode pattern.
Step 4: save to any location you choose.
-Aaron
Do you Yahoo!?
Yahoo! Tax Center - File online, calculators, forms, and more
http://tax.yahoo.com
Re: OS 2.5 ideas
2003-04-15 by psychogroove1
OS 2.5 suggestions
- Real-time transpose (Similar to MC-505) where the entire sequence can be
transposed on the fly, even while running. This would have to avoid the drum
tracks (or not, but probably yes)
- Global Edit , where holding down a particular button would allow the Quick
Edit controls to change all internal tracks. A reset to original settings button
would be a nice addition to this as well so you could return to the normal
Chaos after really messing things up.
PsychoGroove1
> tracks.
> -Aaron
> Do you Yahoo!?
Re: OS 2.5 ideas
2003-04-15 by mikexl7
Aaron you rock!
channel
> tracks.
of
> -Aaron
> Do you Yahoo!?
Re: OS 2.5 ideas
2003-04-15 by xl7772003
Hi All,
Thanks alot Aaron for making us more and more addicted to this little
box ! 2.0 is GREAT !! With all this new functions , now I can do my
stuff far from my PC (in bed !) so every night I'm in cyberspace !!!
What i'd like the most for 2.5 is really REAL-TIME TRANSPOSING (we
hear it in real time, even better we could punch in and out to
transpose not the entire track but say for example from bar 1.3 to
bar 2.4.......With the touchstrip or whatever to set the amount of
transposition , while we punch in&out to select notes that will be
transposed .........It would be Awesome !!
GOD bless you Aaron , may you live forever , or at least until
OS 999999999999999.5  !!!!!!!!!!!
(French sense of humour hope it doesn't hurts !)
Chris
would
pattern.
channel
> tracks.
> -Aaron
> Do you Yahoo!?
Re: OS 2.5 ideas
2003-04-16 by mikedj5000
result.
Re: OS 2.5 ideas
thank you andre, i felt like i was trying to explain some alien
code :D
all good though
> -----Original Message-----
> From: mikedj5000 [mailto:mikedj5000@y...]
> To: xl7@yahoogroups.com
bass
> result.
if
