grid mode problem
grid mode problem
2003-04-11 by A.Ruesberg
when i´m using grid mode on a track, that is set to external, i cannot
set the note with the pad or my external keyboard. i have to use the
scroll wheel to change the note.
the only workaround is to set the track output to both and select a
silent preset, but that´s very annoying.
alexander
Re: [xl7] grid mode problem
2003-04-11 by pocketd@gmx.de
you should assign the track to both and use a silent preset, so you can edit
in realtime.
Christoph
alexander
+++ GMX - Mail, Messaging & more  http://www.gmx.net +++
Bitte lächeln! Fotogalerie online mit GMX ohne eigene Homepage!
