yes it is but why will it allow me to download the 1.32 version and
not the 2.00??
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> What exactly is happening? You are sure your XX-7 is in OS
receive mode?
> rEalm
> chris <djcurious2002@y...>
> 04/10/2003 07:03 AM
> Please respond to xl7
> To: xl7@yahoogroups.com
> cc:
> Subject: [xl7] Re: a liittle more help on the os dl
> still won't execute the download, cables attached. midi tracker
> working but e-loader just won't let me
> dwnld???
> --- In xl7@yahoogroups.com, "M2" <mmcquay@s...> wrote:
> > Within the E-loader program is the OS downloader utility. Once
> your
> > Command Station is in the searching for OS mode, you then lauch
> the
> > OS downloader application. Then select the .dli file(OS)from
> > folder where you saved it to, select your midi device (the midi
> > interface connected from your computer to the XL-both midi
cables
> > need to be hooked up), and then click on the send (download)
> prompt.
> > Within 10 minutes, you should be updated.
> > --- In xl7@yahoogroups.com, "chris" <djcurious2002@y...> wrote:
> > > i have e-loader and the os file but when i hold down the
enter
> key
> > > and power up the display shows, searching for os... and
remains
> > > there?? is something i'm doing wrong?
> Your use of Yahoo! Groups is subject to
