8 Proteus 2000 banks
2003-04-07 by kevinj_j
Hey I found this on the p2500 board.. I can only say one thing
to emu.. You guys rule..
> From: "stevenlebeau" <stevenlebeau@y...>
> Reply-To: Proteus2500Group@yahoogroups.com
> Subject: [Proteus2500Group] Proteus 2000 Presets for the 2500
> Date: Tue, 25 Mar 2003 23:21:13 -0000
> Hi,
> I thought I'd let everybody know that Sean Wilhelmsen at E-mu has
> converted the original 8 Proteus 2000 banks for use in the
> Proteus 2500 and command stations with the Proteus Pop collection
> ROM.
> I've uploaded it to the group (it's in the "Factory Presets"
> directory).
> There are a ton of awesome presets not present in the new Proteus
Pop
> ROM. Have fun!
> -Steven LeBeau
Re: 8 Proteus 2000 banks
2003-04-07 by stevenlebeau
Yes they do! I'd been asking around the P2K group for somebody to
dump these so I could convert them for the P2500/Command Station.
Nobody did, but then two weeks later (after bugging the P2K group a
second time), Sean e-mailed these to me. I think I tried putting them
up on this group, but there was a disk space issue.
I'm trying to get somebody to do the same thing for the Audity 2000
banks, which use the same samples as the Audity 2000 with the
expansion card. Sean explained how it could be done in a previous
post here, but I haven't been able to get anybody to dump the banks
for me to convert. So, if you own an Audity 2000...
-Steven
Re: [xl7] Re: 8 Proteus 2000 banks
2003-04-08 by biz@groovetronica.com
Actually, there isn't any conversion from the XX-1 boxes to the XX-7 - you
just load them in.
This is going to take a lot more work. Ideally, (yes, I'm a broken record),
EMU would give us the patch sysex specs for the two units, and someone can
whip up a perl script to convert the two. Converting them by hand would
probably be so time consuming as to be unfeasible.
Is there any reason why these are public domain? They are for >every< other
synth on the market....
I am currently starting work with a producer who is using a planet phatt for
most of his production. If I could get the same sounds out of my xl-7, we
could save >so< much time....
bIz
2003-04-08 by A.Ruesberg
i found the sysex spec on the emu site :
http://www.emu.com/products/pdf/pdf_manuals/sysEx/protAudSysEx21.pdf
the sysex spec seems to be the same for both synths. the audity2000
page and the proteus page link to this doc.
i took a brief look at the waveforms. it seems like nr 0-287 are exact
the same, nr 288-522 seems to be idenctical with nr 1-235 on the audity
extreme board.
so if we would know the different rom IDs someone might be able to
write a perl converter. i don´t know if there are any other differences.
since i don´t have any experience with perl, it´s up to someone with
perl experience....
basically we all have an audity2000, so at least the factory sounds
should work.
alexander
Am Dienstag, 08.04.03 um 22:14 Uhr schrieb <biz@...>:
> you
> just load them in.
> record),
> can
> other
> phatt for
> we
> bIz
> Make Money Online Auctions! Make $500.00 or We Will Give You Thirty
> Dollars for Trying!
> http://us.click.yahoo.com/yMx78A/fNtFAA/i5gGAA/pWZylB/TM
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
