Problem syncing a Waldorf Q to the Xl7
2002-03-27 by A.Ruesberg
hello
i´ve a serious problem syncing my Waldorf Q with my Xl7. I´ve set the Q
clock to auto and the Xl7 to send midi clock.
when i use percussive sounds (attack set to 0) on both machines, a Q
sound played by the arp or the step sequencer has a constant 20 msec
delay.
does anyone of you know a solution for this problem ? Or is anyone
using a similar setup that works ?
alexander
btw : i don´t have to work till tuesday. today would be a perfect day
for the deliviering the new os ;-)
a new beginning?
2003-03-27 by jason
is there some sort of way i can do a master re-set or something?
maybe i'm not using the right term or missing it in the manual.  but
i want to figure out a way that will erase all editing, sequencing
and any other sort of tweeking i've done and start from "scratch"/
factory-presets.  can anyone help me?
jason
Re: a new beginning?
2003-03-27 by mikexl7
Yep when you turn the box on hold down both the curser keys.  You
will end up in a diagnostic mode.  Scroll through till you see what
i rember to be ini.  You get a couple of options as to what you want
to INI.
Hope that helps.
Mike G.
but
> jason
Re: [xl7] a new beginning?
2003-03-27 by Aaron Eppolito
If you don't want ANY patterns in the box (even the factory ones),
Reinitialize User Data.  If you do want to keep the patterns, do a
Reinit Except Seq.  Both functions are available in diagnostics mode,
accessible via booting up with both cursors held till you see the diag
screen.  The aforementioned items are #16 and #17.  Note that this will
reset EVERY master setting and EVERY user preset, and the full one will
erase EVERY sequence.
-Aaron
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
2003-03-27 by alvinenglish
Aaron,
     Are the Diagnostic Tests documented some where?
> -Aaron
> Do you Yahoo!?
Re: [xl7] Problem syncing a Waldorf Q to the Xl7
2003-03-27 by ->Nobody<-
I believe that's a known problem with the Q, not the XL-7 fault.
I've read somewhere it's a bug.
Check out google or the waldorf list.
"A.Ruesberg" wrote:
> i\ufffdve a serious problem syncing my Waldorf Q with my Xl7.
Sebastien,
Reality is for those who can't handle Star Trek.
