Got rubbers?
Got rubbers?
2003-03-26 by erik_magrini@Baxter.com
Good idea about the transpose settings, will I need to save the preset if
thats the only edit I make?
>>>No, it's a machine wide setting, not a Preset one, so it won't affect
those at all. <<<
Also, you took your XL-7 apart, were you able to seperate the rubber pad
strip from the rest of the part? Thanks for your help man!!
>>>Hmm, trying to remember... I don't think I had to do that actually for
my purposes.  I was only concerned with getting the case free.  Sorry
going from memory here!  I think I just pulled the rubber price off for
kicks though, just to see what was under it.  Either way, the whole
process was very straightforward, so you should be able to tell right away
if you can or not. <<<
