X-MIX
X-MIX
2003-03-22 by joesapo
Props to the EMU folks for putting out a great product and keeping
the support alive.  I can't wait for 2.0 to get here.  ;)  But if you
wanna throw out an OS hint my way I should be able to wait a while
longer...  Any details on how X-MIX works?  Do you just select
another track on another pattern and go with it or what?  Will tracks
be made available via the B channels or maybe with the drum pads?
Will we be able to bring in parts with volume controls?  Just curious.
BTW... the PX-7 looks nice.  I swear I'm gonna paint my XL-7
someday.  The orange is getting anoying.  :)
sapo
Re: X-MIX
2003-03-23 by mikexl7
I too am very curious about the X-MIX feature.  Any one got more
info on this one?  I would love to know more.  Getting excited.
Mike G.
you
tracks
curious.
> sapo
Re: [xl7] X-MIX
2003-03-24 by erik_magrini@Baxter.com
You can select another (Source) Pattern you want to grab tracks from, then
specify which Track in the current pattern the new Track will be assigned
to.  Then you select the Track you want to grab from the second pattern.
You can repeat this process for additional tracks.  Any source track can
be placed at any destination track.  It's much easier to use than to
explain.  Very cool though, makes it dead easy to mix from one pattern to
another.
Any details on how X-MIX works?  Do you just select another track on
another pattern and go with it or what?  Will tracks be made available via
the B channels or maybe with the drum pads?  Will we be able to bring in
Re: X-MIX
2003-03-25 by mikexl7
That sounds like a dream come true for me and the way i like to
perform.  YAHOO.
from, then
assigned
pattern.
track can
to
pattern to
> another.
> rEalm
on
available via
bring in
Re: X-MIX
2003-03-25 by joesapo
Thanks rEalm...
Sounds pretty intuitive.  I guess I'll just have to wait and try it
out.  Props to EMU for adding this MUCH NEEDED feature.  You guys
rock.
Your loyal customer,
SAPO
from, then
assigned
pattern.
track can
to
pattern to
> another.
> rEalm
on
available via
bring in
Re: X-MIX
2003-03-28 by guilt23fr
will the controllers such as volume, pan, arp on/off, and program
number will be imported WITH the trak,
or it will be the current controllers that will be kept?
> Thanks rEalm...
> rock.
> SAPO
> from, then
> assigned
> pattern.
> track can
> to
> pattern to
> > another.
> > rEalm
> on
> available via
> bring in
Re: [xl7] Re: X-MIX
2003-03-28 by erik_magrini@Baxter.com
Arp on/off is a Preset function, not a pattern one so that won't change.
Ie, if the source track uses a preset that has the arp on, the arp will be
on and vice versa.  Volume, Pan, Program Number, and FX Send Amounts will
be from the Source Track, while the effect type will be from the current
pattern.  If I remember correctly that is.  It'll be in the new FAQ (which
is done), I just can't upload it until the OS is out.
guilt23fr <guilt23@...>
03/28/2003 07:08 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: X-MIX
> Thanks rEalm...
> rock.
> SAPO
> from, then
> assigned
> pattern.
> track can
> to
> pattern to
> > another.
> > rEalm
> on
> available via
> bring in
Re: X-MIX
so, if i understand fine : only the sequence (notes+events after the
first tick) will be imported?
that's a good way too imho.
thanks
change.
will be
Amounts will
current
(which
> rEalm
> guilt23fr <guilt23@c...>
> 03/28/2003 07:08 AM
>         cc:
> > Thanks rEalm...
it
> > rock.
> > SAPO
> > from, then
be
> > assigned
> > pattern.
> > track can
than
> > to
> > pattern to
> > > another.
> > > rEalm
track
> > on
> > available via
> > bring in
Re: [xl7] Re: X-MIX
I don't know exactly everything that's imported, just going by what I saw
in use.  We'll have to wait for the release to know more.
thanks
change.
will be
Amounts will
current
(which
> rEalm
> 03/28/2003 07:08 AM
>         cc:
> > Thanks rEalm...
it
> > rock.
> > SAPO
> > from, then
be
> > assigned
> > pattern.
> > track can
than
> > to
> > pattern to
> > > another.
> > > rEalm
track
> > on
> > available via
> > bring in
Re: [xl7] Re: X-MIX
2003-03-28 by Aaron Eppolito
Everything will be loaded from the source track that's in there, with
the exception of MIDI routing.  This means that preset, volume, pan,
arp setting (the one on the preset view screen), and mix output
selection will all get imported from the new pattern.  As rEalm said,
FX settings (like send amounts and FX types) are part of the WHOLE
pattern, so they don't get loaded with an individual track.
The reason for not using the new pattern's channel routing is because
since you can switch track locations (i.e. load 7 into 3), if you used
the source channel, you'd probably be overwriting the settings from
another track.  For most people, this shouldn't be a problem, just make
sure to load internal tracks to internal and external tracks to
external ones and you'll be fine.
> first tick) will be imported? that's a good way too imho.
Nope, other way around... Everything *including* tick 0 will get
imported.
But it's also a pattern parameter (as shown on the preset view page).
It determines off, on, use preset, or use master (off, on, P, M).
-Aaron
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
Re: [xl7] Re: X-MIX
2003-03-31 by erik_magrini@Baxter.com
Thanx Aaron, I forgot about that one.
