i see....
but defining these templates must be a kind of tricky,
i thing, i'll go on on sequencing with sonar i think
:-D
--- erik_magrini@... wrote:
> Groove quantize is just a type of quantize that
> instead of using regular
> note values for it's base (ie, 1/16, 1/8, 1/4 notes,
> etc), it uses premade
> 'templates' that have different amounts of swing
> applied to make them not
> so rigid. It's not the same as using the Swing
> function though, as many
> of the timings aren't the same through the template,
> they vary note to
> note. (I'm doing a horrid job explaining this)
> Basically, groove quantize is just more human
> sounding than regular
> quantizing. It offsets the notes and/or velocities
> by small amounts so
> that the quantizing doesn't sounds as static and
> robotic, and has a more
> life-like character to it. Some companies (namely
> Roland) even organize
> their groove quantizes by musical styles, so you get
> things like raggae,
> waltz, samba, quantize options.
> User Defined Groove quantize is where you can create
> your own 'templates'
> based on midi data that you have created or imported
> already. The
> software looks to see how far each note is from a
> standard 16th note (or
> other note resolution) grid , and saves those
> offsets as a new user
> quantize option. This lets you import, say a midi
> file of funky drum
> loop, into your hardware, then let the software
> analyze and store what
> gives it that human character. Then you can reapply
> those settings to any
> midi parts you want. Perhaps Jesse can explain it
> better.
> Regardless, it's not in the Command Stations, oh
> well. :)
> rEalm
> Hi,
> definitly dont understand a thing about groove
> quantize, it seems to be different from 'simple'
> quantize, what's that thing ?
> [Non-text portions of this message have been
> removed]
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
