upgrading OS
2001-11-16 by InfidelsRe@aol.com
I received my brand new XL-7 and it had the 1.0 OS. I downloaded the updated OS easily enough and unzipped it ok. So I loaded the EZ loader program (I have a microspft java environment apparently version 5.00.3309) and it seemed to load ok. However it turns out if I use the EZ Loader program once and then close it, it hangs when I try to open it a second time. Anyway, once I have it open, I get to the point where I've chosen the file to be sent (the new OS) and the XL-7 LED reads "Searching for OS" and its midi out light is beeping steadily but the download button never becomes available on the Downloader program. Also, the XL-7 is NOT one of the midi devices in the "configure midi device" item so I cannnot choose the xl-7 to send the info to. Why? I have the adpater connected to my PC(running Windows ME) sound card, a Sound Blaster Live! Value card, and the midi out of the computer goes to the midi in of the xl-7 and the midi in of the computer goes to the midi out of the xl-7. Does it make a difference which midi out of the xl-7 is connected? How do I check if the midi on the computer is working since I've done no previous midi work on this computer? What else could I do to get this working? Gerry D
