Sent: Monday, March 17, 2003 3:39 PM
Subject: Re: [xl7] Re: AdV!Ce 0N Wh@T To GeT????
Make sure you have any custom users presets backed up in your XL-7.
step 1: Dump any preset or whole banks from your Audity 2000's user
locations into the XL-7 via sysex. MIDI out of A2K to MIDI in of XL-7 and
then initiate a dump with the A2K. The banks or preset numbers will line up.
step 2: Once the preset is in the XL-7, you will have to reassign the
instruments for each layer and the Arp pattern. Basically anything that
points to the ROM. You will probably have to refer back to the Audity 2000
for assistance in referencing patterns and instruments.
step 3: Save your new preset. Keep in mind these new presets will be using
the Audity 2000 knob layout.
sean at e-mu
To: <xl7@yahoogroups.com>
Sent: Monday, March 17, 2003 2:53 PM
Subject: RE: [xl7] Re: AdV!Ce 0N Wh@T To GeT????
> Ok, what do I have to do? I have an Audity and an XL-7...
> Andre
> -----Original Message-----
> From: Sean Wilhelmsen [mailto:seanw@...]
> Sent: Monday, March 17, 2003 10:38 AM
> To: xl7@yahoogroups.com
> Even thought he Audity 2000 is a subset of the XL-1, the standard presets
> for each do have very distinctive personalities. The Audity 2000 does have
a
> much edgier selection of presets. The group of preset programmers we used
> for each project were different as well as given different design goals.
> Technically you can put all of the Audity 2000 presets in to an XL-1 or
> XL-7. There would be a about 2 minutes of re work required for each preset
> ported over via sysex and you would need an A2K to grab the presets from.
> sean at e-mu
> From: "Ravi Ivan Sharma" <noision1@...>
> Sent: Monday, March 17, 2003 10:25 AM
> > Better to get an XL1 than an audity 2000
> > From: Nick Rothwell
> > Sent: Monday, March 17, 2003 9:50 AM
> > > I myself have just decided to buy the
> > > Audity 2000. I do a dark sort of trance and techno myself and have
> > > found the soundset and arpeggios on the Xl7 to lean more to the
"pop"
> > > side.
> > But the Audity 2000 is almost a pure subset of the XL-7, so if you
> > don't like the XL-7 the Audity doesn't have much to recommend it,
> > except that (i) it's smaller and (ii) it's very cheap at the moment.
> > nick rothwell -- composition, systems, performance --
> http://www.cassiel.com
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
> > To unsubscribe from this group, send an email to:
> > xl7-unsubscribe@yahoogroups.com
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> > [Non-text portions of this message have been removed]
