Archive for xl7.
Re: [xl7] polyphony
Re: [xl7] polyphony
2001-08-24 by Aaron Eppolito
There is no fixed limit.  It'll play as many notes as you record into it.  If
you've got external gear hooked up as well, you'd have as much polyphony as
all the synths hooked up (including the 128 XL-7 voices).
-Aaron
curiousproductions@... wrote:
> what is the total note out polyphony of the sequencer?
> is it 128 voice ?
> i know the synth can generate 128 voices, but it is not listed in the
> specs what the sequencer can put out.
> Just curious
Re: [xl7] Re: polyphony
2003-06-19 by Ravi Ivan Sharma
Oh brother . . .
  Sent: Thursday, June 19, 2003 10:49 AM
  Subject: [xl7] Re: polyphony
  --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
  > *NO ONE* that I know of in the ROMpler/sampler world counts layered
  > presets as one "voice".  Stereo sounds use two voices.
  > Layered sounds use at least one voice per layer.  This is not
  > deceiving on the part of
  > every synth manufacturer, it's just what the terminology is.
  > By the way, I forgot to mention that 12th order filters use 2
  voices.
  When you consider how much bulk E-Mu puts into its manuals and how
  prominently the "128-voice" capability is promoted, it is absurd that
  E-Mu doesn't come out and say what other manufacturers have freely
  admitted.
  Please show me in which manual or addenda there is any explanation of
  how anything other than chorus reduces polyphony (number of playable
  voices).  Do the manuals say that stereo samples use two audio
  streams?  Perhaps I missed that.  Do the manuals say that 12th order
  filters use two audio streams?  What else eats up audio streams?  And
  where are audio streams explicitly equated with layers?
  BTW, I am comfortable saying current E-Mu gear has 128 audio streams.
  Will we also find out that multi-samples also use multiple audio
  streams--that (for example), an E-Mu instrument [ROM sample] that has
  28 drum different samples (a kit) uses 28 audio streams?
  Why can't E-Mu just do what other manufacturers have done in the past
  and be up front (as my previous posts from Casio and Roland manuals
  show)?
  Read the E-Mu manuals, please:
  INTRODUCTION:  Ultra Powerful Synthesizer
  "The extremely flexible yet easy to use 4-layer synthesizer voices
  make it easy . . . ."
  "128 voice polyphony ensures that you can play and sequence the most
  complex material."
  The first sentence clearly refers to a 4-layer structure as a voice.
  Two sentences later, the reader/user/consumer/potential buyer has no
  reason to believe that 128 voice polyphony is not 128 4-layer
  synthesizer voices.
  It would be very easy to say, "The extremely flexible yet easy to use
  4-layer synthesizer presets make it easy . . . ." and "Up to 128
  complex material" or even "E-Mu's unique 128 audio stream
  architechture ensures that you can create, play and sequence the most
  complex material."
  In order to demonstrate that the hype in the intro is not intended to
  be misleading, it would be nice to see in future manuals and addenda
  a note referring to a brief section summarizing 128 audio stream
  architecture as it rleates to layers, number of simultaneous notes
  that can be triggered, polyphony, etc.  E.g., "(See page 12 for an
  overview of E-Mu's unique 128 audio stream sound engine.)"
  BTW, how does an E-Mu user know which samples [aka ROM instruments]
  are stereo and which aren't?
  Please don't misunderstand, I like the E-Mu architecture and am very
  pleased with the flexibility it has.  In fact on this board and
  others when users have had problems/complaints, I have been very
  liberal with my praise of the architecture's flexibility (so much so
  that when someone asked if the big data knob can be used to send
  program changes to external gear and someone else said they didn't
  think so, I wrote a utility pattern that demonstrated two ways that
  it could be done.)
  Also, having worked with real patchcords extensively on the original
  Moog, I appreciate E-Mu's virtual patchcord architecture,
  terminology, and flexibility.  I have openly praised them when others
  have questioned them, and I have created sample patchcord solutions
  to posted problems to show how flexible they are.
  However, I did not like finding out after several months that I do
  not have an "Ultra Powerful Synthesizer" with 128 4-layer voices and
  I certainly did not appreciate the way in which I found this out.
  Huh?  "The extremely flexible yet easy to use 4-layer synthesizer
  voices make it easy . . . ."
  E-Mu clealy refers to "4-layer synthesizer voices."  The gear has 4-
  layer presets.  [presets = voices]  Thus, in every introuduction of
  every manual that has this line E-Mu is counting a 4-layer preset as
  a 4-layer voice.
  If other manufacturers also equate the number of layers with
  polyphony (number of triggerable voices) without describing how the
  architecture uses, reduces, chews ups, eats, robs, etc.
  voices/polyphony, I would also claim they should improve their
  manuals.
  8-)
  Steve
        Yahoo! Groups Sponsor
              ADVERTISEMENT
2003-06-19 by erik_magrini@Baxter.com
Funny, I never thought it meant anything other than what it really is.  I
mean, isn't that the same way all Romplers are (layers use up voices)?
Semantics aside, it's pretty cut and dried to me.
admitted.
2003-06-19 by Greg Waltzer
I have read the manuals for proteus 2000, XL-1 and XL-7 many times over
the years, and I have never been confused about what a voice is.
The fact that they can be layered adds programming flexibility and
power, it doesn't reduce polyphony. Even when you play four instruments
with one key press, that is not a 4-layer "voice", it is 4 voices
layered. Each of those voices has it's own sound, completely
programmable independently of the others.
Perhaps the manual could have been written more clearly. I've never seen
a manual that couldn't.
Consider that Emu participates actively in this forum and others. And
not just to promote their stuff - they answer questions and provide
information we wouldn't otherwise get (Thanks Aaron!).
You don't see that from Roland, Yamaha or Korg.
BTW, at current prices, you can get two XL-7s for less than what you
would pay for equivalent functionality from other manufacturers. Try
that if you're seriously worried about running out of voices.
>admitted.
>show)?
>complex material."
>synthesizer voices.
>complex material."
>it could be done.)
>a 4-layer voice.
>manuals.
>8-)
>Steve
Re: polyphony
2003-06-19 by steve_the_composer
--- In xl7@yahoogroups.com, "Ravi Ivan Sharma" <noision1@h...> wrote:
> Oh brother . . .
> The casios you mention never had more than 8 voice polyphony no
> matter how many dcos or "lines" per voice were available.
My CZ-5000 still has 16 note polyphony when a one-line preset is
played live.  By that I mean that I can have 16 note-ons triggered at
a time before any previously played notes will be cut off.  To me
that's polyphony.
I'm sorry if I offended you with my desire for accuracy.
Brother Steve
8-)
PS: BTW, on each of the CZ-5000's 8 sequencer tracks, I can have as
much external polyphony as the Command Station (or other module) can
handle--even though internally the CZ sequencer is limited to 8
voices.  (Yes, I am acknowledging that in sequencer mode, the CZ has
8 note local polyphony.  8-)
Gotta be different, it's the artist in me you see!
How's about everybody smiles now?  (hoping to extinguish this minor
flame war...)
-Aaron
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
I AM REALLY OFFENDED! Oh brother again.
  Sent: Thursday, June 19, 2003 12:34 PM
  > Oh brother . . .
  that's polyphony.
  Brother Steve
  8-)
Re: polyphony
Sorry I offened you again.
Please lighten up; don't be offended.  Forgive this old-timer for
trying to get caught up with new uses for old terminology.
I can remember when the first polyphonic Moog came out (early '70s).
A music store salesman tried to tell me monophonic meant you can play
more than one note at a time and polyphonic meant you can play only
one note at a time.
I still think he had it backwards.
Of course, the 1969-1970 generation Moog could have multiple notes
sounded simultaneously but only one key at a time on the keyboard
could trigger the complex sound.  Back then it was called monophonic.
Yet, when I sent the output of 2 different envelope generator
controlled VCAs through two trunk lines into a two track tape
recorder, I had stereo. I suppose it could be called 2 voice non-
polyphonic stereo.  ;-)
And to think, 33 years later each E-Mu layer (that is, each
monophonic voice of which my Command Station has 128) has at least a
billion times the functionality and complexity of the Moog.  Phew!
--Steve 8-)
Don't take Ravi too seriously, he's a lawyer (AND a New Yorker!), they
make a living (AND a past-time) by being offended :)
steve_the_composer <smw-mail@...>
06/19/2003 02:44 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
one note at a time.
--Steve 8-)
Now I am REALLY offended! (and offened also!) :)
  Sent: Thursday, June 19, 2003 3:47 PM
  Subject: Re: [xl7] Re: polyphony
  06/19/2003 02:44 PM
          cc:
  one note at a time.
  --Steve 8-)
2003-06-19 by aeon
On 6/19/03 10:15 AM, "erik_magrini@..." <erik_magrini@...>
No...Kurzweils can add layers to a single voice, and it does not take away
from polyphony...you get 24/48 (depending on the model) voices, each with
1-3 sample-based layers.
cheers,
aeon
Re: polyphony
--- In xl7@yahoogroups.com, aeon <aeonlux@a...> wrote:
> On 6/19/03 10:15 AM, "erik_magrini@B..." <erik_magrini@B...>
> > really is.  I mean, isn't that the same way all Romplers are
> take away from polyphony...you get 24/48 (depending on the model)
> voices, each with 1-3 sample-based layers.
> cheers,
> aeon
Thanks for the comparative info.
--Steve
Re: polyphony
2003-06-20 by Brian
take away
each with
I don't believe this is correct. If my memory serves me, the K2000
series has 24 voice polyphony (like you said) and up to 96
oscillators - up to 4 oscillators per voice. However, only one of
those oscillators can contain a sample, the other three can only be
simple waveforms (i.e., sawtooth).
If you have a program with more than one layer (each layer capable of
playing a different sample), that will reduce polyphony. On the
K2000, a 3 layer voice will reduce your polyphony from 24 to 8.
The K2500 has double the polyphony and oscillators of the K2000.
-Brian
2003-06-20 by aeon
>> from polyphony...you get 24/48 (depending on the model) voices, each with 1-3
> I don't believe this is correct. If my memory serves me, the K2000 series has
> 24 voice polyphony (like you said) and up to 96 oscillators - up to 4
> oscillators per voice. However, only one of those oscillators can contain a
> sample, the other three can only be simple waveforms (i.e., sawtooth).
> If you have a program with more than one layer (each layer capable of playing
> a different sample), that will reduce polyphony. On the K2000, a 3 layer voice
my bad!
correct, 1 "layer" can be a sample, but the other (up to 3) are all
analog-style waves.
that'll teach me to comment on gear I do not own without checking my sh*t
first!  =)
mea culpa,
aeon
