re: Bring it On
2001-08-05 by Aaron Eppolito
Wow, didn't take someone long to find the pattern
change hiccup! We're
releasing 1.01 which fixes that very problem! Check out the Emu website
either Monday or Tuesday for it!
-Aaron
PS. glad you found it intuitive and easy to use, that was probably my number
one goal!
To: <xl7@yahoogroups.com>
Sent: Saturday, August 04, 2001 7:02 PM
Subject: [xl7] Re: Bring it on!
> I played it for about 20 minutes (felt a little guilty, since I
> already have one in the mail).
> The grooves that comes with are >really< busy, and the ones I found
> were pretty much all straight 'trance/euro techno' styles. If this
> had been my first impression of the unit, I would have been seriously
> turned off :> But since I'm migrating from the p2k and used to have
> the xlead rom, I know what the sound engine and ROM is capable of, so
> I was stoked to hear so much going on at once, and hear the amount of
> flexibility and life could get from the track system.
> The unit is moderately intuitive, despite the plethora of knobs and
> actions available at any one time. I'm sure that most actions will
> become unconcious quickly - the sign of a good ui. With the realtime
> controllers, you need to know which knobs do what to which sounds, or
> you won't get what you expect, just like the p2k/xl-1.
> My biggest peeve, and it was either something to do with the way the
> unit was set up, or a >serious< bug - when switching between grooves,
> the unit LCD would flash and the beat would be lost momentarily - it
> was not seamless at all. The MP-7 sitting next to it didn't display
> this - it switched smoothly. If that shows up in the unit I get on
> monday, I'm going to be pretty concerned. However, I think this would
> be unlikely, since the unit is pretty much set up for seamless
> transitions - it waits till the end of the groove to switch over.
> It's going to take a lot of work to get the most out of this beast -
> since you can have an entire 64 midi channel groove on each of the
> sixteen tracks, it's really easy to get over-noisy, if you aren't
> 100% sure what you are turning on at any one time. One thing I found
> myself wishing for was a latchable track system - where turning on
> one track turned off another. Emu?
> My 20 minutes,
> sserendipity
> --- In xl7@y..., "Mark McQuay" <mmcquay@m...> wrote:
> > I just came back from the local music store, where they have just
> set
> > them up.
> > Well...................and then? ( from Dude Where's My Car?)
-Aaron
one goal!
> My 20 minutes,
> sserendipity
> set
> > them up.
