--- In xl7@yahoogroups.com, "Jean Kergutuil" <jean.kergutuil@a...>
wrote:
> hello
> Try to put the sysex delay on 300ms ...
This is not the original poster's problem.
Note that the SYSEX PACKET DELAY parameter is NOT applicable to OS
updates (nor to Sequence transfers when using E-Loader). That
parameter is only used in open-loop (non-handshaked) transfers. OS
updates are done closed-loop (handshaked) and do not require fixed
delay times between packets in data transfers. Closed-loop transfers
occur at the maximum speed that the unit can accept MIDI and use
check-summed packets and support retries in cases of
dropped/corrupted packets.
