Vol record
Vol record
2003-02-16 by pocketd@gmx.de
I did think a bit about programming volumes an easier way than recording the
main volumes as you do it in
the main volume screen.
I´m often getting confused recording volumes, cause I can record above a
maximum level I choosed before,
besides the volume setting is reapeating as the pattern loops again.
So, I thought about setting one layer with that cord:
L1 Midi O-> Amp Vol  +100 (setting vol.-96)
L2 Midi 0 -> Off
L2 Midi P -> RTX Fade (setting Vol. 0)
So, what I can do now is recording Midi O, for example a fade in, and as the
pattern ends I program a RTX
switch, so that the volume is now at a constant level.
I think that´s useful, cause I can´t control every track on my mixer.
I´m not sure, if it´s the easiest way, but what you get is a better control
I think, and using Preset links u can
still get complex presets.
Is there someone, who does it that way?
cy,
Christ
+++ GMX - Mail, Messaging & more  http://www.gmx.net +++
Bitte lächeln! Fotogalerie online mit GMX ohne eigene Homepage!
