Index last updated: 2026-03-31 01:49 UTC
what is going on?
what is going on?
2001-11-10 by mikexl7@yahoo.com
I am using the XL to control my E5000 but evry time i go into the
edit the loop points in the E5000 i cant control the loop points due
this constant sliding of the loop.  It is supper odd becous i dont
see any midi info going in or out of the XL, the only reason i am
posting here is it did not do this befor i hooked the XL up to it.
If this turns out to be sompting withen the E5000 sorry to bug ya all
with it.
Peace
Mike
Re: what is going on?
2001-11-11 by bigben@mac.com
Well I'm not sure but it sounds like what happens with my e6400
Ultra... When editing samples the start and end times can be
adjusted with the pitch bend wheel via MIDI.  So if you're trying to
edit the loop points of a sample on your e5000 while playing a
sequence from the xx-7, and have pitch bends in the sequence,
that would cause the problem you described.  As far as I know
there is no way to disable this "feature,"  you just need to stop
play on the xx-7 or take out the pitch wheel messages when
editing the samples.  That's my guess...
Big Ben
due
ya all
> with it.
> Peace
> Mike
2001-11-15 by mikexl7@yahoo.com
Thanks for getting back to me bigben.
I know what you are talking about there but it continues to happen
when the sequencer is stoped! And the pitch controller has no affect.
I don't get it.
Another thing i dont understand is this.  I have my FX sends set up
as i want them on the E5000 then i hit stop twice and the FX change
to other sends! This would be supper cool if i could control them
some how but I i have no idea what my XL is sending that might me
dooing it.  I have the program change dissabled on the E5000 so it
can't be that.
I dont get it, and it be anoying!
I would love to hear form one of the E-MU boys on this stuff ;)
Hope some one out there knows what this stuff is all about.
Peace
mike
to
> Big Ben
> the
> due
dont
> ya all
> > with it.
> > Peace
> > Mike
Re: [xl7] Re: what is going on?
2001-11-15 by Aaron Eppolito
EOS and XL-7 both use controller #79 to control FX sends.  XL-7 stores these
values for each used track.  To edit them, go to the global menu to the MIX
OUTPUT page.
-Aaron
> can't be that.
> Peace
> mike
> to
> > Big Ben
> > the
> > due
> dont
> > ya all
> > > with it.
> > > Peace
> > > Mike
2001-11-15 by bruce@sigalarm.com
Actually, that sounds pretty annoying. But there is some heavy duty
fun that can be had with the modulation of sample start point
parameter.
If you have a waveform that is a set of sources stacked (like say 8
of them) doing a PPG / Walforf style sweep.  The sample is about 2
seconds and loops, but it more or less goes through this spectral
mutation along the way.
Then you make a preset to run with an arp, so it is short and sort of
percussive, make a bit of decay with some delay as well.
Then have a tempo locked LFO move the sample start point around, what
happens is that the timbre of the sound changes over time (say the
LFO is set to 4 measures).  Pretty wild effect as the character of
the sound is changing dramatically.  All of this without using the
filter at all.
Bruce
affect.
> I don't get it.
> can't be that.
> Peace
> mike
> to
> > Big Ben
> > the
points
> > due
> dont
am
it.
> > ya all
> > > with it.
> > > Peace
> > > Mike
Thank's again aron Eppolito!
that is ultra good to know.  I will look at that tonight.
Peace
Mike
stores these
the MIX
> OUTPUT page.
> -Aaron
Re: what is going on? Bruce! dude come to IBGEEK :)
dude thanks for responding.
You might want to come to IBGEEK.  I am trying to get someone elts
talking in there other than me aron and scott.  It would be cool to
see you there.
Like I have to say that this is some great geek talk here below :)
  I am in love with the note retriger with LFO right now.
of
what
> filter at all.
> Bruce
Sweet sweet geek talk.  I have also had some great luck with
recording odd voice stuff, like layering my two way radio that i use
for work (bike courier) with some beats.  Like all the clicking and
so forth.  I am going to talk to the folks at this fire hall and see
if i can record there horns and sirens so i can use the waves.  I am
totaly digging the new microphones I picked up a couple of months ago.
Envriomental sounds are a great as wave forms.  Like take a odd lip
smack or the sound of hitting a pen on a desk and use it with a arp
or retriggerd LFO and run it through some reverb and it be sweet.  I
could go on but ill save it for IBGEEK ;)
Peace
mike
