Why the XX-7 is worthless piece of crap.
2003-02-11 by nifflas <nifflas@musician.org>
Now I'm mad!!!!!! I got my first XL-7 when theese machines was new. After some months, the data wheel began to act weird and generate strange data. I sent the XL-7 back, and got a new one. After some more months, it's data wheel becan to act just like the last one. Then some buttons got worse. And NOW, when I got home after the weekend, the sound output, was REVERSED!! The reverb was panned somewhat to the left. And no, it's not my headphones. It's the XL-7! This happends with ALL outputs, both the headphone and the other outputs. No one else have ever touched my synth while I was gone, and I've done no change to the synth configuration, or repleaced any audio cables or ANYTHING. It's exactly the same as when I left it before the weekend. Nothing I done could have caused this problem, because I did absolutly NOTHING. Okey, I know theese synths is based on low-quality components which sooner or (in case you're really lucky) later stops to work, but THIS SORT OF THINGS IS NOT SUPPOSED TO HAPPEND WITH A SYNTHESIZER! Not to mention the bugs in the OS. I've had nothing else than trouble since I bought the XL-7. Also, keep in mind that I'm really careful about my music equipment. I do nothing which can damage it. This is not my fault.
