I use the xl7 to controll a emuE5000 as well as my digitech studio
quad. I use a behringer quad gate to keep the noise floor down on
the fx unit. I use the fx in line off the two sub outs off the xl7
only. I sum all of it into an alesis mixer. Then off the main outs
of the mixer i go into a beringer tube composer, it is a gate then a
compresor-limiter-tube exciter. I use a behringer ultra curve ex
side chained with the compressor to make shur that things are
compresed with out pumping and breathing. then off of that into a
MAudio sound card into the pc with wave lab. Phew*
that is how i do it. I set it up this way so i can pick up and go
out to the club with out my head exploding each time. takes me
about 15 min to set up my live pa in a clup now thanks to a wack of
soldering.
Just one more way of doing things.
Mike G.
--- In xl7@yahoogroups.com, "Erika <erika_ev1@y...>"
<erika_ev1@y...> wrote:
> Well hi!!
> I just bought one of these things and figured it out pretty quick,
no
> thanks to the manual.
> I'm just getting my own studio setup though. I had an XP-30 which
I
> sold to finance the XL-7. I would have liked to keep it, but it
> lacked a sequencer and I had pretty much put my writing on hold
until
> I got my hands on a hardware one. It's pretty simple to write my
> songs and get them straight on the XL-7, but I also want to
> eventually sequence other external gear. Have a Korg poly 800 I
will
> be adding and am wondering what combinations of hardware software
you
> use to record the final mix. Do you run it into a multitracker, a
> multi input sound card? record it as a mixdown into a minidisk or
> computer?
> just looking for suggestions.. thanks!!
