Archive for xl7.
Re: testing a used xl7
2003-02-08 by unleashdabeasst <unleashdabeasst@yahoo.c
hold down both cursor buttons while powering up
UDB
--- In xl7@yahoogroups.com, rob caldwell <alocaster2001@y...> wrote:
> I want to buy a used xl7 and I would like to know how
> to check the device out. Having read the manual and
> not finding any kind of self test listed, I thought I
> would stop lurking and post. For example my kurz has a
> routine for checking the dials buttons etc called the
> keyscanner, and it has a test for the hardware broken
> into different areas. Thanks
> Rob
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
> http://mailplus.yahoo.com
2003-02-09 by alocaster2001 <alocaster2001@yahoo.com>
sorry to appear so dim but what will that test? What is the expected
response from the device.
Rob
--- In xl7@yahoogroups.com, "unleashdabeasst <unleashdabeasst@y...>"
> UDB
> > Rob
> > Do you Yahoo!?
Re: [xl7] Re: testing a used xl7
2003-02-09 by Aaron Eppolito
> What is the expected response from the device.
There's a whole diagnostic menu.  It will test just about anything you
ask it to, including flash, RAM, ROM, audio path, front panel, MIDI, etc...
Do you Yahoo!?
2003-02-11 by CM
I'm also testing a used MP-7. when I perform the tests I get a "MIDI test
failed-Port A In/out Jumpered?"
Does anyone know what this means. Also is there a description of the error
messages anywhere?
To: <xl7@yahoogroups.com>
Sent: Saturday, February 08, 2003 8:04 PM
Subject: Re: [xl7] Re: testing a used xl7
etc...
> Do you Yahoo!?
2003-02-11 by Aaron Eppolito
> test failed-Port A In/out Jumpered?"
To test the MIDI ports, you need to plug a cable into the back,
connecting the In to the Out (so it can loop back MIDI to itself).
-Aaron
Do you Yahoo!?
2003-02-11 by CM
Thanks, everything looks good so far..........
  Sent: Tuesday, February 11, 2003 3:38 AM
  -Aaron
  Do you Yahoo!?
