Fw: Easy way to record and separate tracks in cubase?
2003-02-05 by David
Sent: Wednesday, February 05, 2003 2:36 PM
Subject: Easy way to record and separate tracks in cubase?
I have a question for the CUBASE guru's in here.  Is there an easy way to dump my audio into 16 tracks in cubase?  I would like a track for each sequenced track.  Right now I'm just subbing each track of each pattern of the song and hitting the record button. . .
Painful...
Re: [xl7] Fw: Easy way to record and separate tracks in cubase?
2003-02-05 by Jonathan El-Bizri
Yes - everything at once, then split by channel.
Alternately, use the USB port.
bIz
  Sent: Wednesday, February 05, 2003 12:52 PM
  Subject: [xl7] Fw: Easy way to record and separate tracks in cubase?
  Painful...
2003-02-05 by David
I thought of that but my problem is that I have different instruments in
different parts of the song...
To: <xl7@yahoogroups.com>
Sent: Wednesday, February 05, 2003 3:02 PM
Subject: Re: [xl7] Fw: Easy way to record and separate tracks in cubase?
> bIz
>   ----- Original Message -----
>   From: David
>   To: xl7@yahoogroups.com
>   From: David
>   Painful...
>   [Non-text portions of this message have been removed]
That shouldn't be problem - the program changes are recorded too.
  Sent: Wednesday, February 05, 2003 1:06 PM
  > bIz
  >   From: David
  >   From: David
  >   Painful...
2003-02-05 by David
oh
cool.
Sent: Wednesday, February 05, 2003 3:55 PM
>   From: David
>   From: "Jonathan El-Bizri" <sserendipity@...>
>   > bIz
>   >   From: David
>   >   From: David
way
each
of
>   >   Painful...
2003-02-05 by David
Do I have to change each pattern to Dest: both unnder channel assign?  I'm
recording the input, but the track is showing up under ALL channels - 1-16
in cubase...
>   From: David
>   > bIz
>   >   From: David
>   >   From: David
way
each
of
>   >   Painful...
2003-02-06 by erik_magrini@Baxter.com
Well, the only way I can think of to speed it up, would be to use a
multiple input sound card an then the sub outs on the XL-7.  At least then
you could 6 tracks at a time in theory (3 tracks in stereo), though you'd
lose the effects on the sub outs.  Other than that, I can only recommend
what I do, one track at a time and read a magazine while it records :)
Painful...
