New user feeling a bit overwhelmed
2003-02-03 by kaniner2003 <Skymountain1@aol.com>
Hello! I'm a new user of the X-l7 and new to the world of midi and synthesis in general. If anyone has time... maybe you could throw a couple of words of encouragement as to the glory of the device and the creative rewards that I will reap some day.... My main problem is that I'm used to working with computer software such as ACID and doing things in a very visual way... I'm having difficulty making the transition to this device that operate entirely in cyberspace with a tiny LCD sceen. Thanx for your comments Darren
2003-02-03 by Andre Lewis
Hey welcome! I know everything can be a bit overwhelming at first, but really it's not so bad. The first thing that you should know in general is to use your ears. Being visual works, and with Acid it seems so easy to put something together like that. The thing is when you are working with music soetimes it's better to hear what's going on more than seeing it on a screen. I know that at first it seems so hard, especially when you have something in your head that wants to get out, then you get caught up in how to just start recording it and you can get caught up in the details. But after a while as you get used to how things like the XL-7 work you will find that you can get what you want down VERY quickly. Always remember that you don't just get on a bike and magically know how to ride it, you have to fall over a couple of times and practice a little bit then one day you'll be like "Wow! I can't believe Madonna opened for me!". You won't even have to think about the gear. In the meantime: Most synthesizers have two major sound modes: Patch (Also known as single) and Multi (or performance). Each patch is usually made up of up to four samples which can play at the same time, crossfade into each other or some may even play after you let go of a key. A multi is a way of saying you can play (Typically) up to 16 patches at once. The XL-7 is by default in Multi Mode, where each channel plays a sound and generally corresponds to a Midi Channel (Midi supports up to 16 distinct channels of note and other information). So if you plug a keyboard into the midi in on the XL-7 and play something on Midi channel 1 on the keyboard, you will hear the sound on the XL-7 that corresponds to Midi channel 1. Another thing most synthesizers do is actually split out the part that sequences the note information so that the sound portion responds exactly the same way for midi information comming from outside the synth as it would on it's own sequencer. This means that anything you can tweak or change on the XL-7 you can pretty much do remotely from some other piece of hardware or even a software sequencer. You can even tell a sound on a midi channel to change to a different sound using a program change midi message. That way at the begining of your song or pattern the correct sound will play. Most people on this list will actually write the music using a software sequencer like Cakewalk Home edition or Cubase VST, Cubase SX, Sonar, Pro Tools, and even oldschool atari sequencers. Once they have finished with the song they save it out as a Midi file and then send it over to the XL-7 using their USB port. Now they can play back their song at any time without a computer. In fact they can also control other equipment with the XL-7 using that same midi file! The other thing that will help you out in the beginning is to read the FAQ on the Yahoo Groups website that this list is attached to. It may help clear up a lot of questions on how to record into it, play back things from it, demo sounds etc. Also the manual is great and there is an update available for the manual and the OS. You should make sure to download it and read through it, it has great tutorials and once you get your feet wet you can ask the list anything and we will try to answer. Good luck and congraats on your purchase, It's a great piece of kit- Andre
2003-02-04 by erik_magrini@Baxter.com
Welcome! I would say the biggest thing, is to not get too discouraged
right away. Anytime you get a nerw piece of gear, esepcially one that's a
sequecer, synth and a controller in one, there's going to be a learning
curve. As always, practice makes perfect, so the best thing you can do is
just keep trying to use it, and the more time you spend on the XL-7, the
more it will start to make sense. Other tips (applies to all new gear,
not just the XX-7):
- Read the manul. Yeah, it seems obvious, but so many people seem to skip
this step. When you first get some new gear, sit down with the manual and
just go through it quickly. You're not trying to remember everything at
this stage, just get an overall impression of how things are organized,a
dn what the box is capable of doing. Now go back and try and play around
with it some more. Keep an eye out for menus you noticed in the manual,
or jot downa ny questions you have on things that seem unclear. Now, go
back to the manual and look up the answer to those questions, but be sure
to actually apply them hands on with the unit too, you'll remember them
better this way. Once you're comfortable with how things are laid out and
you can navigate your way around all the different screens and menus, then
you should go back and really READ the manual, focus on the little things
this time around.
- Don't take on too much right away. People get new gear and expect to be
able to knock out a complete track in no time when they still have a lot
to learn. Don't get mad if you can't do something you can show your mates
right away! :) Tackle a differetn topic each day. For instance, one day
you could sit down and focus on tweaking and saving your own sounds, the
next day you could focus on using grid record, the next day you could try
and see what all the midi menu options do, etc.
- Don't be afraid to ask here for help. That's what this list is for and
we have some great producers and artists on ehre willing to help out when
they can.
- Get some inspiration from these XX-7 only tracks:
http://www.EmuCS.iuma.com All of those tracks were made with JUST the
XX-7's and nothing else for a contest we just had.
- Read the FAQ I created. If you didn't get it when you subscribed, let
me know.
"kaniner2003 <Skymountain1@...>" <Skymountain1
02/03/2003 04:56 PM
Please respond to xl7
cc: Subject: [xl7] New user feeling a bit overwhelmed Hello! I'm a new user of the X-l7 and new to the world of midi and synthesis in general. If anyone has time... maybe you could throw a couple of words of encouragement as to the glory of the device and the creative rewards that I will reap some day.... My main problem is that I'm used to working with computer software such as ACID and doing things in a very visual way... I'm having difficulty making the transition to this device that operate entirely in cyberspace with a tiny LCD sceen. Thanx for your comments Darren To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
2003-02-04 by pocketd@gmx.de
Hi, I think we start at the same position I mean I was an absolute beginner at midi and synthesis, I do play a bit guitar, but just on my own, I did never play in a ban, so that makes it more difficult for me. The technical side of midi and synthesis in avery general way and learning how the XX-7 works stole a half year way of my lifetime, a lot frustration, but alot fun, too. Now I can modulate some instruments and play around with them, I don´´t know too much sythese tricks so far, but once you understand the subtractive synthese it´s getting much clearer how you can use the parameters in an automation process. U can use midi events or modulate one of these parameters by an LFO or an envelope, the patchcord screen is a really heavy thing in the XX-7, so just see these parameters first: Volume and Filter, first of all U set the volume envelope and next think about what the filter should do and set its stages. If u understand that U nearly have it, everything else can wait. First of all, play around with the knobs, so you see what they do, I had many problems using the envelopes first, so program an ADSR envelope (see manuals), that´s much easier. For example there`s a dependence between the Decay and Sustain and the sustain and release stage, once you get it. There are so many parameters of course that´s confusing, so u should first just use the volume envelopes and filter envelopes as I described above. I reduce my sounds and use a BD,SN,HH and some percussions (a drumkit is enough first) and a sawwave as a bass and a synth sound, everything else did me just confuse. Program an easy groove in grid record or something more complex if u like and play somehing with the sawwave to it, that gets me into music. Besides i first started to modulate drumsounds that did help me, too. See all the different ways to record data in the XX-7 and see what could be right now. There are a lot of specific things you can´t learn in the manuals, so I wouldn`t be at that point without the list, but first start with the manuals, I hate them, cause it´s just too thin. Read Books, magazines, everything you can get and get the puzzle together... Well, my german is better, the way above is my individual way, I did never use the factory sounds and patterns, I have a record player for that, just my opinion... Hope it helps a bit, Christoph -- +++ GMX - Mail, Messaging & more http://www.gmx.net +++ NEU: Mit GMX ins Internet. Rund um die Uhr für 1 ct/ Min. surfen! [Non-text portions of this message have been removed]
