I like what you are dooing there, you got me thinking.
might just dive in to the fx a little more today.
Thanks for the responce.
Mike G.
--- In xl7@yahoogroups.com, "joesapo <joesapo@y...>" <joesapo@y...>
wrote:
> Well I kinda have been using whatever is on 16B as a control
preset,
> keeping generic sequences in them and using them to help with
pattern
> changes and FX. The preset is composed of 4 layers of generic drum
> and bass instruments that I can use in transition sequences. I
also
> route FX sends to the QuickEdit knobs so I can change FX levels
> realtime and have their values stored in presets. Then I'll choose
> what FX I want and save that stuff with the preset. That way when
I
> go to 16B when playing live I can change the preset and shuffle
around
> what FX are loaded. Also I try to keep an arsenal of generic
> transition sequences in the preset. What I do is setup a preset
knob
> to control a realtime crossfade (RTXfade) to switch the active
layer
> in the channel. Then I'll sequence data to each layer individually
> with a drum roll, or some sort of break or something cool for a
> pattern switch. That way I can "dial in" what break I wanna use
and
> transistion to the next pattern. It works okay. I just make sure
> that track 16 (what i have for MultiB) is turned on in all my
patterns
> that I wanna use. If you have any more questions feel free to ask.
> I signed up for IBGEEK. There's some good archived info there.
Thanks.
> sapo
> --- In xl7@yahoogroups.com, "mikexl7 <curiousproductions@r...>"
> <curiousproductions@r...> wrote:
> > I would love to know how you went about setting this up. I know
how
> > and have delt with using the preset as a control for pulling up
fx
> > settings. I would just like to know how you felt it was best to
> > deal with setting this up and using the knobs as fx send
amounts.
> > Eg. how what knobs do what in your setup.
> > I also would love to let you know about a group that i set up a
long
> > time ago that seems to have died for the moment called IBGEEK
you
> > can find it under the links section of this group. It is for
talkig
> > about this kinda stuff.
> > Thanks
> > Mike G.
<joesapo@y...>
> > wrote:
> > > I have been toying around with the FX settings on my XL7 all
day
> > and
> > > I've come to a decision on *how* to route them, but now I need
to
> > > choose which ones to use. I've settled on running in multi
mode
> > and
> > > having a 'control' preset on channel 16B, routing all the FX
sends
> > to
> > > knobs. This way I can not only control the FX sends in real
time,
> > > but also switch that MIDI channel to other FX setups stored on
> > other
> > > presets. So my question is this: What are the two most
useful FX
> > on
> > > the command stations? I've been pretty much using Delay on my
FXA
> > > and Distortion2 on my FXB.... What does the forum think? The
> > more
> > > general use I can get out of them the better.
> > > sapo
