Archive for xl7.
Re: [xl7] hello
Re: [xl7] hello
2001-08-22 by Aaron Eppolito
curiousproductions@... wrote:
> I don't think that got any answer to my previous question so im sorry
> for repeating myself.
> So i take it that there is no way to place program changes withought
> using a computer sequencer?
When you save a pattern, it will save a program change at the beginning of
each *used* track corresponding to the preset on the channel that the track
references.  Two things to note here...
First is that a track must have data for it to store its initial state (vol,
pan, arp, preset, etc).  If you want just an empty track with initial events,
just record some little blip of a controller or something, and then when you
save the pattern, it will write events into that track.
Second is that tracks don't necessarily have to be one to one mappings with
channels (as assigned in the second to last screen in the pattern edit
menu).  The channel data saved on the track is the one that it is assigned
to, and for Multi tracks, it saves every channel for which there is data in
that track.
Also, you can record program changes into your sequence in realtime record
mode from MIDI.
That being said, if you want to insert a program change (or any other type of
event) anywhere in your sequence, using the display (like an event list type
thing), maybe if you clamor enough, we E-mu people might listen and release
it in a software rev... =)
> Also, has anyone elts noticed a slight glitch when you pres the enter
> button to set the new pattern as active?  it only seems to happen
> when there is a larg pattern. It was happening very offten when using
> 8 to 32 bar patterns.
Very important:  Make sure you have the latest (1.01) software.  This fixes
glitches between patterns (albeit at pattern change time, not selection
time).  This may or may not fix your problem.  If it doesn't, or you already
have 1.01, let me know...
> that aside i am rely enjoying using this box, it is verry refreshing
> and musical compaired to the computer sequencer platform.
I'm glad you enjoy it!
Cheers,
  -Aaron
PS. nice track BTW!  what sound are you using for that cool octave jump
motif?
Re: [xl7] hello
2001-08-22 by Jonathan El-Bizri
This information is sent out the external out if that, or 'both' is selected for the track?
I don't seem to be able to get channel program changes to affect external units. Is there a way to do this?
What about clamourings for:
- track groupings (so switching on one track turns off any others in it's group)
- 64 bar patterns (especially useful for high bpm styles)
- force pattern change at end of a chosen number of bars (0, 1, 2) (you'll really need this with 64 bar patterns)
- Making the knob wheel require a confirm to switch tracks, when any changes have been made to the tracks would have saved me more than one really killer groove. (Currently, you only confirm when the sequencer is playing)
- Being able to disable the Record button (and any other editing buttons) would make me feel a lot more secure in a live setting. I've accidentally hit it several times while practicing, and can only imagine things being more hectic when I start playing out in a couple of months.
- Would there be any way to group patterns so that controller and master settings persist between them (so that when you switch to the next section of a song, the pan/controllor settings remain the same)? This would make it a lot easier to use patterns together in a live setting, since you wouldn't have 'jumps' in filters and effects settings between sections.
- change knob control to volume/pan when those display pages are selected, or vice versa.
(yes, I'll >never< be satisfied with anything)
I would prefer a way to control external unit parameters without performing an event edit, myself.
I know of the glitch, and I have the 1.01 software installed. When you select the pattern, rather than the pattern starting, it sounds like all midi off notes stop being executed until the next pattern is loaded. It's not the same as the 'pause' between the patterns in 1.0
I've also noticed that using the 'cut' command on a track doesn't deactivate it's 'track light button'. Is there are reason for this? I've also manage to crash my xl-7 once, using the cut command. I was cutting tracks while the sequencer was playing - so I could hear what each track was doing, on a copy of the preset BLUR, copied to a user bank, (I was taking out the melody tracks to keep the drums). I was on track 12, and the cut command stopped everything. I had to kill the power to get it back. Foruately, I had not done much editing other than cutting at that point.
Yes, I'm having a lot of fun with it too :> I've never used a hardware sequencer before. Cool. (though coolest when used with software)
Jonathan
Re: hello
2001-08-23 by curiousproductions@hotmail.com
--- In xl7@y..., Aaron Eppolito <aarone+xl7@e...> wrote:
withought using a computer sequencer?
beginning of
the track
(cut to end of quote)
record mode from MIDI.
Ok my question here is can i send a dump somehow from a E-MU E5000
somehow in order to get this to work with external gear? does that
even make sence?
other type of
list type
release
CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR
CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR CLAMOR!
:)  Ok i have to say that that a list editor is realy needed on this
thing.  I would be supper supper happy if you got one in there
somehow i would even bake you muffens or cookies and send em down to
you if you did it.  MMMMMMMMMMMMMMMM cookies are soooo good you like
cookies don't you, home made cookies and a glass of cold milk,
MMMMMMMM yummy.
> > Also, has anyone elts noticed a slight glitch when you press the
enter
using
This fixes glitches between patterns (albeit at pattern change time,
not selection
you already
I am running 1.01
refreshing
> Cheers,
>   -Aaron
> he he.
jump
> motif?
Thanks alot, um is that not a secret ;)he he he.
Re: hello
2006-08-17 by milesegan
beginning of
the track
state (vol,
initial events,
when you
mappings with
assigned
data in
> that track.
Sorry to dredge up this old post, but I'm not having any luck getting
my PX-7 to send program changes to my synths.  Is the above still true
in the latest software revision?  I don't see any program changes in
the event list editor after I save a program and the PX-7 doesn't
appear to be sending any.
Manually inserting the program changes in the event list editor
doesn't seem to work either.
Re: [xl7] Re: hello
2006-08-17 by Aaron Eppolito
Certainly don't worry about dredging up posts, it means you're using
search!
Make sure your tracks are set to external in the screen near the end of
the pattern edit menu.  Otherwise, it won't transmit program changes.
Note that "both" is not enough, since it assumes that the chances that
you'd want to same exact program change on the internal synth as your
external synth is about zero, so it sends the pc only internally.
-Aaron
> true
> beginning of
> the track
> state (vol,
> initial events,
> when you
> mappings with
> edit
> assigned
> data in
> > that track.
Do You Yahoo!?
http://mail.yahoo.com
Re: hello
2006-08-17 by steve_the_composer
What are your channel assignments for tracks going to external
synths?  Dest. should be ext. Dest. = both doesn't do it.
Also, to see program changes on internal tracks, set Dest to ext.
and look at tick 0. If you've already entered the event editor, you
may have to reload the sequence to see tick 0.
Hope this helps.
--Steve
--- In xl7@yahoogroups.com, "milesegan" <milesegan@...> wrote:
[snip]
getting
true
in
FOR FURTHER DETAILS:
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
> If you want to see the events in the event viewer, temporarily set
> track to external. When set to internal, it hides the events that
it
> puts in at tick 0 so that the casual user doesn't delete events
that
> the sequencer puts in there.
> If you want to fix the program changes, however, you don't have to
use
> the event editor at all. Just set up the presets with the main
screen
> and resave the pattern.
> -Aaron
http://groups.yahoo.com/group/xl7/message/17052
Re: [xl7] Re: hello
2006-08-18 by jibarosoul@aol.com
is there a way to surf thru presets on an external mudule thru the px-7? My
asr-x pro does this perfectly but on the px-7 you have to send a program change
just to change a preset.
Re: hello
2006-08-18 by steve_the_composer
For all practical purposes, no.
Years ago I discovered one way to do it, but it wasn't very
practical. As I recall, using remote control mode (via sysex) I
created a very short pattern (1/16th note, maybe) that when looped
constantly at a fast speed read the turing of the data know and sent
out program changes.  It was not worth the effort.
If for some reason, you must have this feature; I could probably
give you insights into sysex/remote control programming.
--Steve
> px-7? My asr-x pro does this perfectly but on the px-7 you have to
> send a program change just to change a preset.
Re: hello
2006-08-18 by milesegan
> search!
I double-checked that the track is set to ext, and tried sending some
program changes from another synth on the same channel just to make
sure everything was working and that I didn't have some kind of filter
in my midi chain, but still no luck with the PX-7.  I'm sure I'm
missing something obvious though.  I also tried inserting a program
change in the middle of the sequence in case it was something weird
about the first event in the sequence, but that didn't seem to make
any difference either.
Thanks for your help.
Re: hello
I double-checked this after surfing through some messages on this
group but it didn't seem to make any difference.  I also tried several
target synths just in case it was some peculiarity of one instrument,
but with no luck.
By reloading the sequence do you mean saving it, switching to another
sequence, then back to the original?  I haven't tried that yet.
