Re: [xl7] MIDI editor
2003-01-09 by David DeciBel
Can anyone recomend a good simple MIDI editor for editing text & sysex from
my xx7?  I use CUBASE but it's a bit large to edit plus i'm having some
problems exporting to smf...
Re: MIDI editor
2003-01-09 by Loops / La Bloukak
Hi all and thx for tips...
i have the same problem with Cubase, when i export my file under .mid SMF,
cubase put 2 blank bars at the beginning of the file, and of course it
doesn't loop in the machine sequencer...
does anybody has a solution ? maybe change of sequencer, but i will prefer
another solution of course ;o)
Loops
Message: 17
   Date: Wed, 8 Jan 2003 20:38:11 -0600
Subject: Re: MIDI editor
Re: MIDI editor
2003-01-10 by Loops / La Bloukak
Yeeeaaaahhhh ! THAT'S IT !
Thank you very much, i was looking around for a solution with another
sequencer, but at last it was a little parameter to change....Pffff...
Good vibes to you
Loops
Message: 3
   Date: Thu, 9 Jan 2003 06:54:03 -0600
Subject: VST adding 2 bars
You need to change the preroll amount (or is it the start offset?) it
sounds like (the default is 2 bars).  I think that's under the
synchronization menu in VST.
"Loops / La Bloukak" <bloukak@...>
01/09/03 04:14 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: MIDI editor
Loops
