the lighting attachment and the new OS v. 2.0???
2003-01-08 by plasticefx@aol.com
In a message dated 1/7/03 5:26:39 PM Eastern Standard Time,
geraldayoung@... writes:
> Hey Plasticefx
> Yes, I had exactly the same problem... when the light is attached,
> the XL7 goes ape and boots/reboots every 2 seconds infinitely...
> lights flashing and speakers popping... the whole bit.
> Your guess about the light is on the money. It turns out that some of
> these lights run a little hot when the connection between the bulb
> and the socket is a little less than perfect. This causes the tiny
> wire they fished through the flex neck to become de-soldered from the
> little disk contact in the bulb socket. A little shifting here and
> there and all of a sudden the wire contacts the shell of the lamp
> assembly and POW... POW....POW...POW!
> I managed to fix mine but there was not much wire to work with and I
> have no confidence in the repair... it will probably fail when I need
> it the most... of course.
> Hope this helps.
> Ger
Ger:
that's it exactly bro.  my wonderful emu accessory came apart too.  cheap
piece of shit.  i'm gonna either go without or find some other compatible
light that ACTUALLY WORKS.   emu gave me the shaft when i tried to contact
them.  not really cool considering i bought it thru the website.
bastards....
plastic
p.s. how do other peeps update the OS w/a powerbook and the xl7.  any help?
i'm looking forward to the v.2.0 and wanna get the most current update.  and
is sound diver the preferred software.  what would be a hotass software
recommendation for the xl-7 and a new powerbook running mac's OS X.
connections????
Re: [xl7] the lighting attachment and the new OS v. 2.0???
2003-01-08 by drK
> connections????
Use the Emu loader software running under MIDI to do the update.  No other
software required.
Hot software in conjunction with the XL-7?
1. Investigate using Ableton Live along with the XX-7 with the XX-7 as the
controller for Live.  I think they pair well together.
2. Use Reason as a "rack-o-gear" for the XX-7.  The NNXT sampler in Reason
is a fairly well specified sampler.  the other synths and effects are also
fun and complement the XX-7's synth well.
3. Almost any of the Native instrument's software instruments used in stand
alone mode with the XX-7 as the controller and sequencer.  Need a powerful
sampler? Kontakt.  Big synth? Absynth, Pro53, Reaktor.  DX-7 clone? FM-7.
Lots of great virtual sound modules".
4. Almost any MIDI sequencer can be a good complement in that you can freely
move MIDI files to and from the XX-7 using the Emu E-loader program.  Lots
of possibilities there, including improving the XX-7's sequence editing.
5. See if Emu announced the availability of the Emulator 5 software sampler
at NAMM next week.
BTW everyone one of the above suggests will work equally well on a PC.
(subject to the usual "my platform is better than yours" debate :-) )
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
