To: <xl7@yahoogroups.com>
Sent: Monday, January 06, 2003 8:01 PM
Subject: Re: [xl7] Repeat Button
> --- David DeciBel <spec@...> wrote:
> > I'm trying to insert a patter in the middle of my song. What I'm
> > doing is this:
> > Putting my cursor under the step (this case it's step 6) - and then
> > holding down REPEAT and pressing enter at the same time. It takes me
> > to the NEXT step, but doesn't insert...
> > Any ideas?
> Performing the steps you mentioned will do nothing (but you already
> knew that...) I thought the manual was correct on this, wait, nope,
> just checked and it's wrong (at least my version is, maybe later revs
> are right). Think of the repeat button as a "split" button. It will
> only divide an existing step into two steps at the bar you are
> currently at. This was originally because I thought most people would
> have linear song tracks that they wouldn't want sliding around. I've
> since changed my mind (well, let's say my mind was changed...) so this
> might be one of those things that work better in 2.0 (hint, hint).
> For now, to split a song step, go to a bar somewhere in the middle of a
> step and hit repeat, optionally change the pattern, then hit enter.
> For example, if pattern step 1 is 16 bars long, go to bar 9 and press
> repeat. Pattern step 1 will now be 8 bars long, and you'll have a new
> 8-bar step 2 at bar 9. The old pattern step 2 will remain at bar 17,
> but will be renumbered to step 3.
> If you want to do the normal idea of repeat (yeah, I know, smack me) go
> to the step after which you want to insert, change its length to
> include the length of the pattern you want to insert (this slides the
> song data down!) then go to the bar that you want the new step at and
> press repeat.
> This "split" behavior will still exist in 2.0, but additionally, if you
> "repeat" while at a step beginning, it will do the normal thing (i.e.
> slide down the song data and insert a new step of length equal to the
> length of the current step).
> -Aaron
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
> http://mailplus.yahoo.com
