controller info
controller info
2002-12-24 by mikexl7 <curiousproductions@rogers.com>
i am trying to record midi controller datta on a track set to
external.  The Controllers are set up right becouse the are
effectively controlling the program I am using in my E5000 but the
info is not recorded.  I am a little confused here can some one
offer a hand?
Also it seems that no one has had the problem that i am having with
the program on track #1 not changing with the patterns?
And it is true that no one knows how to get into the diagnostic
layer of the OS?
man please help if you can i would be most appreacitive of any help
i am stuck.
Mike G.
Re: controller info
2002-12-24 by multiproximus <binker@iname.com>
Not sure about your other questions, but I do know how to get into
the Diagnostics... you need to hold down both cursor keys while the
unit is powering up.
MP
--- In xl7@yahoogroups.com, "mikexl7 <curiousproductions@r...>"
> offer a hand?
> layer of the OS?
> i am stuck.
> Mike G.
Re: controller info
Thank you very much.
It seems that i have a midi loop back problem now that i know this
only if i knew how to fix it : \
well thanks for getting me one step further
Mike G.
--- In xl7@yahoogroups.com, "multiproximus <binker@i...>"
> MP
> > offer a hand?
with
> > layer of the OS?
help
> > i am stuck.
> > Mike G.
