Re: sequencing external samples
2002-12-20 by deknoww <deknow@netzero.net>
a few things to consider:
1.  the midi cc and pc message numbers in the repeater manual are not
all correct...you should look in the files section of the yahoogroup
repeater group (or check the archives) for accurate numbers.
2.  the repeater is not a sampler, and does not behave like one.  i
mostly use my repeater from the front pannel, so i can't give
specific steps, but you might consider cueing up the loop you want
from the repeater ahead of time, and let the emu do the equivilent of
pressing the play button on beat one of a new sequence.
3.  i find in my own production, that using several sequencers synced
is more fun (and more musical) than just using one master sequencer
to controll everything (and yes, i know that you could accomplish
most things with a single sequencer, but i find it beneficial to be
able to change one sequence, and keep some elements from changing at
the same time...without complete planning beforehand).  that said,
you might consider just using the repeater manually while it syncs to
midi.
4.  unless you are doing live looping (recording or overdubbing in
realtime while you perform or record), you would probably benefit
from a more traditional sampler..as the repeaters strongest point is
it's live recording of loops.
deknow
--- In xl7@yahoogroups.com, <acopolis@s...> wrote:
> So It seems like this should be one of the main things that this
machine can
> do but I don't see anywhere in the manual that tells how to do it.
> I want the MP7 to select and start loops on my repeater but I have
no clue
> how to go about this.
> It seems like you should be able to program the program change or
control
> changes into the  song on the MP7 so that the appropriate samples
will be
> selected and triggered automatically. I no that the repeater can be
> controlled via midi I just don't know how to program the MP7 to
tell it what
> to do. It seems that I just need the MSB/LSB command to go out a
bit before
> I need the sample to start so that it can load and then send the
start/play
> command. Is it possible to automate this? HAPPY HOLIDAYS!
> peace, acopolis
> www.space380.com
2002-12-20 by acopolis@space380.com
So It seems like this should be one of the main things that this machine can
I want the MP7 to select and start loops on my repeater but I have no clue
It seems like you should be able to program the program change or control
changes into the  song on the MP7 so that the appropriate samples will be
controlled via midi I just don't know how to program the MP7 to tell it what
to do. It seems that I just need the MSB/LSB command to go out a bit before
I need the sample to start so that it can load and then send the start/play
peace, acopolis
www.space380.com
