probs with Patterns
probs with Patterns
2002-12-16 by pocketd@gmx.de
I just can´t get all the settings right if I turn off my XX-7, it makes me
really mad.
Here´s what I`ve done,
-all the tracks, even the B-channels (on an ext multitrack) have an event on
tick 01:01:001
-I set all the presets, volumes and pans
what the XX-7 does (not always), most of the presets have changed, even the
int. one, I´ll turn off  the XX-7, perhaps everything is allright, perhaps
not..
what´s always right are the channel assignments, the global menue changes on
the ext.tracks.
What should I do?
I need the ext.channels for prog.Changes on my external modules, so they
should be routed ext not both, so that the internal programs wouldn`t change.
Should I make settings even for the internal presets at tick ...001 with
Pan, Vol and progr. changes?
That would be hard work.
Ah, forgot one thing, I route int. tracks to B-channels and ext to
A-channels, that was the only way to play external module by a keyboard with merge A
and channels 1-16A set in the Midi dialogue.
Thanx,
Christoph
Neu: Fakten testen jetzt noch günstiger 35% billiger + ein Geschenk Ihrer
Wahl!!
http://bonus.gmx.net/?gid=41442879&prid=687
