Chn/Pan settings driving me crazy
2002-12-12 by jesse_medway <medway808@hotmail.com>
Can someone please tell me how I get my Chn/Pan settings
for each track on each separare pattern to stick?
For some reason if I set them the way I want they stay,
other times they go back to some other setting.
I notice that sometimes if I change them then hit stop 3 times
they go back.  Are the channel/pan settings saved in
the track data for that sound?
What i dont understand is how I was able to make some
patterns save the change and others don't.
Right now I am only trying to get track 8 which is using
channel 8 to have the same settings over about 5-6 patterns.
I got all of them right except for two of them which keep
going back to these other settings.
Jesse
Re: Chn/Pan settings driving me crazy
ok, after reading the previous message looks like
this is a bug.  so is the fix to jsut keep trying
it over an over?  do you actually need to hit save in
order to make the settings stick?  because i have
had the settings retained even when i didnt hit save.
the light never flashes so i assumed you dont need to.
--- In xl7@yahoogroups.com, "jesse_medway <medway808@h...>"
<medway808@h...> wrote:
> Hi,
Re: [xl7] Chn/Pan settings driving me crazy
2002-12-12 by erik_magrini@Baxter.com
Do you have other data recorded on that track?
"jesse_medway <medway808@...>" <medway808
12/11/02 08:33 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Chn/Pan settings driving me crazy
Jesse
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
What do you mean by other data?
So far it seems the way around this is to keep setting
it to what i want and then saving.  After about 3 times
it saves properly.
> rEalm
> "jesse_medway <medway808@h...>" <medway808
> 12/11/02 08:33 PM
>         cc:
>this message have been removed]
2002-12-13 by mikexl7 <curiousproductions@rogers.com>
Ya rEalm I do and thanks any way i had not thought of that.
> rEalm
2002-12-13 by donron29669 <donron8@juno.com>
I have to save the patterns after any such changes to make them
stick,Jesse.
> > Hi,
Re: [xl7] Re: Chn/Pan settings driving me crazy
2002-12-13 by jm213213@aol.com
I saw in the manual how to overdub in song mode but I cant find how to do it
for a pattern.  How do I perform this feature?
2002-12-13 by erik_magrini@Baxter.com
If you are trying to save those settings to a track with no other midi
data (note, cc, whatever) they will not save.
12/12/02 01:36 PM
        cc:
        Subject:        [xl7] Re: Chn/Pan settings driving me crazy
it saves properly.
> rEalm
> 12/11/02 08:33 PM
>         cc:
What are you trying to overdub?  Quick Edits or Volume/Pan changes?
jm213213@...
12/12/02 11:09 PM
        cc:
        Subject:        Re: [xl7] Re: Chn/Pan settings driving me crazy
it
> rEalm
> Iam trying to overdub the whole channel... I didnt like what i recorded on
> that track so I just wanted to redo it..
2002-12-16 by MOBO963@CS.COM
Just hit your Pattern Edit Button.
{Dial} to your Copy Section.
Copy the Track you want.
Don't forget to hit the [Home Enter] Button.
After That {Dial} To your past Section.
Past Track Where You Want it.
To a different track or to a difforent pattern.
