Simple little OS feature request
2002-12-11 by Nick Rothwell
This one *must* be simple (or alternatively, totally impossible): can we have a flashing or solid block for the cursor rather than just the flashing underline? It would make editing a lot faster by cutting down the squint-to-find-the-cursor time. (I suppose it might mess up the Mix->Volume page though.) -- nick rothwell -- composition, systems, performance -- http://www.cassiel.com
2002-12-11 by realm619 <erik_magrini@Baxter.com>
Speaking of which, anyone else having problems with settings made to volume in the mixer page not being saved everytime? Ran into this last night when I was adjusting the levels of my tracks in a pattern. I would cursor over and use the Data wheel to change the volume to what I wanted, then save the pattern. Sometimes the pattern would save with the correct settings, other times the previous settings were still retained. I tried to use the Stopx3 to reload the pattern parameters (both before and after the save), though that didn't solve it either. This was a weird bug to me, as performing the exact same procedure to replicate it didn't always work. Sometimes it would save the changes, sometimes it wouldn't. I couldn't figure out why it did this, but I was able to reproduce it readily with numerous patterns. I'd say it only saved the changes correctly 1 times in 3. Anyone else confirm this? rEalm --- In xl7@yahoogroups.com, Nick Rothwell <nick@c...> wrote: > This one *must* be simple (or alternatively, totally impossible): can > we have a flashing or solid block for the cursor rather than just the > flashing underline? It would make editing a lot faster by cutting down > the squint-to-find-the-cursor time. (I suppose it might mess up the > Mix->Volume page though.)
2002-12-12 by David DeciBel
i've had that happen before. Sometimes there are little querky things like this that happen.. Go figure. ----- Original Message -----
From: <erik_magrini@...> To: <xl7@yahoogroups.com> Sent: Wednesday, December 11, 2002 9:16 AM Subject: [xl7] Re: Simple little OS feature request > Speaking of which, anyone else having problems with settings made to > volume in the mixer page not being saved everytime? Ran into this > last night when I was adjusting the levels of my tracks in a > pattern. I would cursor over and use the Data wheel to change the > volume to what I wanted, then save the pattern. Sometimes the > pattern would save with the correct settings, other times the > previous settings were still retained. > > I tried to use the Stopx3 to reload the pattern parameters (both > before and after the save), though that didn't solve it either. This > was a weird bug to me, as performing the exact same procedure to > replicate it didn't always work. Sometimes it would save the > changes, sometimes it wouldn't. I couldn't figure out why it did > this, but I was able to reproduce it readily with numerous patterns. > I'd say it only saved the changes correctly 1 times in 3. Anyone > else confirm this? > > rEalm > > --- In xl7@yahoogroups.com, Nick Rothwell <nick@c...> wrote: > > This one *must* be simple (or alternatively, totally impossible): > can > > we have a flashing or solid block for the cursor rather than just > the > > flashing underline? It would make editing a lot faster by cutting > down > > the squint-to-find-the-cursor time. (I suppose it might mess up the > > Mix->Volume page though.) > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
