MC909 Micro-Review
MC909 Micro-Review
2002-12-09 by Ravi Ivan Sharma <noision1@hotmail.com>
Thanks to my friend at Sam Ash NYC for the heads up, I got to spend
about an hour with the MC-909 today.
I won't be repeating specs or anything like that, we all know that
stuff. If you don't you can find such online on the Roland sites.
Also take into consideration that this micro-review will probably
highlight what I don't like as to what I do like. The reason is that
I am already a groovebox fan and a big fan of the MC-505 and for the
most part I love the specs and most of the functions of the MC-909.
Therefore I spent my time with it today try to *use* it as I would
live, going into presets, isolating parts, tweaking and moveing on,
building grooves on the fly and trying to play rps, lead lines on
the keypads and switch patches on the fly, modifying effects on the
fly etc.
I was interested in feel and how things worked more than anything
else. I did not spend any time whatsoever with sampling except to
fiddle with the timestretching on some of the samples in some of the
presets. Smooth and and what you would expect. I can't therefore
comment on the ease of sampling, the sound quality, or the way in
which a sample gets set up to be time stretched, etc. That will be
on my next visit if any.
Synthesis: If you are familiar with mc-505 or any of the jv or xv
units this is exactly the same. 4 layers per patch available and for
the most part it is all layed out on the front panel. Nothing new, I
didn't spend enought time to find any major differences and frankly
I expect none.
Look and feel: It looks good! It feels good! my arms rested nicely
on it as I tweaked away. Like the edges on the mc-505 they are just
big enought to rest your hands/arms on. The Command Stations are
even better with their fat ears. While it is actually quite big, it
doesn't seem so until you see it next to an MC-505. In fact the 909
looks to the 505 in almost perfect proportions as to what the 505
looks to the 303. It was quite the family to see them all lined up.
Papa bear, mama bear and baby bear totally!
Well I am hear to say that although we all know that baby can't hold
a candle to mama, mama still has a few things on good ole dad and
may even call the shots when out on the town. My conclusion below
that this instrument would be better termed a groove-studio than a
groovebox.
Use: My overall impression is that while Roland makes good use of
the screen real estate, they may have gone a little overboard. Most
of the functions that were available (and visible) using the keypads
and the shift and function keys on the 505 are now buried in the
screen menus. No more shift|x or function|x to get to the parameter
you want to access. The screenprinting on the MC-909 is
disconcertingly empty of information. Now you key into the F buttons
under the screen and dive down a level or two and then are given a
screen with all the parameters which you then scroll to using the
direction keys and then modify using the wheel. Its all layed out,
but in the end it is more work and not so immediate. Maybe its a
toss up as to what is better, but I can say that if you forget about
the features and functions on the MC-505, all you need to do is look
on the faceplate and there they are. The MC-909 forces you to delve
into the screens or the manual to see what is available.
The keypads. Nice rubber not too small and the small size
nonetheless is a good trade off to get more octaves than say the
Command Stations. One gripe: Since the pads are all the same color,
despite the fact that the faceplate below them is painted to
represent the white and black notes, it is hard to intuitively play
the pads like a mini piano in the way that the colored keys of the
505 and 303 and the staggered keys of the Command Stations do. I
could see myself coloring the black keys with some sort of
translucent marker or something in order to make my life easier.
Roland should have done this for us IMO. The key velocity action is
nice. But I didn't see, however, a way to set the velocity curve of
such pads. There seemed to be only a choice of preseting the keys to
either "real" or any one of the 128 fixed velocity amounts. Also
there was no way to assign (that I could see) a particular velocity
response to each key. The parameter was for all the keypads at once.
In practice this is a bit limiting. Also, while I can see wanting to
set the pads to 127 (full) rather than "real," it is less apparent
why setting them to other values is that useful since you have to
dig down into the menues to get to the parameter. In step editing I
can see wanting to changed the velocity per note as you add to your
pattern, or in drum-machine style, as you add different sounds to a
beat. But since you have to dig down through the menu each time you
want to make a change, I could see this becoming very very tedious.
Bottom line, without some keyed "shortcuts" as I believe the 505
has, you have less speedy work ahead of you if you want to be
precise.
The buttons to the left of the keypad: RPS its all there. Nice the
way you hold RPS and a minibox on the screen pops up and allows you
to scroll visuallly throught the rps sets. Same goes for pattern
select, nice. There is a hold button that works as advertised. The
new button is chord memory. This works in much the same way as rps:
you pre-set your chords in a different menu and save for later.
I.e., a major triad, or a minor 7th etc. You construct whatever
chords you like and store them in chord presets. Now when playing
when you press and hold the chord button, the mini window pops up
and you can scroll and choose your chord type. Now when the chord
fucntion is enabled, you can play the keys and get the chords. What
was missing is the obvious function and what I thought it was in the
first place: Like my old Akai AX80 all you had to do was play a
chord and hold it and then press the chord button, then the button
would light and then each key would play that chord structure based
on whatever note. I tried this at first and it didn't work. I held a
simple two not chord and hit the chord button, no dice, just played
the preset chord that was pre chosen. The buttons are wider than on
the 505 so it was hard for me to hold down a four note octave
spanning chord with one hand.Aha, the HOLD button! I pressed hold,
hit my chosen chord notes, they all held, then I hit the CHORD
button which lit. Then I turned of Hold and played the keypad and lo
and behold, NO DICE. just the pre chosen chord. So much for live
spontaneity. This will be a reoccuring theme of this review.
Mixer and part mutes, etc: The part mute/select button works as
advertised as on the 505. The mixer button immediatey jumps you to
the mixer view from whereever you are. This is nice. There is a Part
Assign button that lets you toggle back and forth between having the
sliders address tracks 1-8 and tracks 9-16. Interestingly on the
mc505 the bottom 8 buttons were for the Rhythm parts. Now the bottom
8 buttons are for full on tracks 9-16, BUT in all the patterns
Roland has adhered to the recipe to place the rhythm sounds there,
with kick on track 9 and snare on track 10 and you get the picture:
if you had your eyes closed and just had your hands on the mute
buttons, and were listening to preset patterns, you would be able to
tell whether you were working a 505 or a 909! Only now you need not
devote the bottom 8 tracks to only percussion as on the 505.
The mixer view screen shows you all 16 tracks at a glance with the
Level Sliders represented on screen and three virtual knobs above
each slider per track. One for pan, one for pitch and one for reverb
send. While the Part Assign button toggles a wireframe box around
each of half of the mixer (either 1-8 or 9-16) the F buttons under
the screen let you choose to highlight either of the 4 tweakable
choice per track. This is in contrast to the mc505 which has a
button with dedicated leds next to the sliders which indicates what
the sliders will do.
What is missing from the 505? Well I will tell you: Megamix for
starters, enough said. But what else? Yikes! Where's the "delay
amount" parameter? What about an "effects on/off" parameter? Both
gone! Instead all you have other than level, pitch and pan is . . .
REVERB?? What you prefer if you had a choice per track for readily
available live tweaking: Reverb or Delay/Efx? Well the 505 gives you
all three. If left with one, I would choose delay. Hell there is
even a spare F button with NO FUNCTION just an empty space on the
screen which they could have devoted to a single fx send. Seems like
they didn't get to the coding for that for some reason.
The 909 doesn't have a Delay per se, other than the compressor and
reverb and mastering section it has FX1 and FX2. Surely they could
have let us use the sliders to controll one of the FX?? So how do
you fiddle with a particular track's efx levels on the fly? It is
not a pretty story. You hit Effects menu button and see a diagram of
the fx flow. You then use the directional keys to highlight the
track parameter, then turn the knob to choose say track 11, i.e.,
highhat, then you use the direction keys to move around the diagram
to choose the signal flow. You have every permutation possible and
one nice thing is that you can run through one, a couple or more
effects and then go to an external out. This is nice because before
on the mc505 the external outs were strictly dry. You can say route
your track 11 to bypass the compressor and the reverb directly and
go through FX1 and then route some of the output throught the reverb
and then to the master outs while the mixe with the rest of the
signal that you didn't route through the reverb.
Okay fine. This is all great. But this is what you have to do if you
want to add some delay (fx1 set to a delay) to a particular track.
No quick and easy button press and slider move such as possible with
Reverb, pan, pitch or level. What this also means is that you cannot
tweak any fx send level (other than reverb) simultaneously on more
than one track by moving multiple faders. Can't do it. And what
about the overal FX levels, reverb levels, etc? A quick scan of the
face of the mc909 shows you that such three knobs are GONE. Yup, you
can only set levels and such from the menu after diving down. In
fact, the fx send and output levels are set PER track, not also
globally, i.e. like the extra return tracks on a mixer. Not there--
its as if they are all up full and it is up to you to set the send
amounts on each track only.
Now lets compare to the MC-505. There is a reverb, a delay and 1 FX.
You can easily tweak the reverb and delay sends for each track using
the sliders. You can easily turn off and on the efx to each track
using the sliders too. No matter what the tracks are set too, you
can reach and grab and twek down or up the overall delay or reverb
or effect and even with a sinle button press use the dedicated knobs
to change how much the delay or FX sends to the reverb and such; you
can even tweak the effects quickly--such as delay time--in this way.
Now the MC-909 has all of this (except global return levels as I
have said (or perhaps I missed it)) and has MORE flexibility, but
you aren't doing it quickly or intuitievly.
To be fair the MC-909 does have three knobs dedicated to FX, but
they are freely assignable knobs that I don't believe will have a
uniform function. I.e., I think what the TWO buttons will do will
depend on what Effect you choose with the THIRD Effect type knob.
There is a knob assign buttons that gives no information as to what
it does and the knobs don't have any type of shift function noted.
(and I didn't have time to figure it out) But, let me put it this
way: if you are not completely sure what those knobs will do while
you are in a particular pattern (that has called its own effects up)
that you somehow dialed into while jamming or performing live in an
improv situation (like I often enjoy doing) then you are a sucker if
you touch one of those three knobs or buttons, because what happens
next is anyone's guess!
So this brings us back to the theme of my time with the MC-909. Like
the chord button and the rps and the patten select and the effects
sections and basically all the parameters, this box can do a lot if
you spend some time before-hand setting everything up. On the fly
stuff is just not as happening or possible as on the MC-505, even
not considering Megamix, the omission of which is simply madness--I
observed absolutely nothing about the pattern functionality of the
MC-909 that would prohibit Megamix.
(Okay I can't resist a little rant here again: Roland's statement
that losing megamix is tradeoff of having 16 tracks is the dumbest
thing I have ever heard--so much for increased technology in five
years--imagine having megamix extended to the tracks containing the
separate drum parts, the ability to megamix in a different kick or
highhat while maintaining the remaining rhythm parts in a way that
is impossible on the 505 unless you devote extra tracks to such
rhythm parts--If the 909 allowed that I guarantee that there
wouldn't be such a dribble of actual ownership on the mc-909 list)
This is why I said earlier that the MC-909 is more of a GrooveStudio
than a Groovebox. Yes, yes, yes, the sampling and the on-the-fly
timestretching of samples makes the live prospects of sample use
very very exciting and for the first time possible with the MC-909.
And the chord function is a nice addition to the rps and the pattern
select features which are very live plusses! The turntable slider?
Big Whup. I see no extra functionality than pressing BPM and quick
turning the big knob on the MC-505. If Roland really wanted to make
that huge slider useful they would have made indents along its
length which you could set to meaningful intervals for pitch, like
thirds or fifths or octaves. Images, slide to the indent and get a
perfect fifth or octave? Sounds good right? Well forget it, start
practicing your theremin skills because it is simple a static dbeam
modulator the way it is. Speaking of dbeam I didn't try either of
them so I can't comment. Actually I forgot to try them out, which is
pretty much how I treat the dbeam on the 505. Bad parent! Bad
Parent! Ah the poor dbeam.
Back to live functionality. Aside from the sample stretching
niceties, the inability to meaningfully or consistently tweak
effects levels other than reverb is simply an astounding ommission
to me given the knobage devoted to matering effects and some other
less live-important new features. Given the choice I gladly would
prefer one of the envelope sections disappear and let one toggle
between VCA and Pitch so as to make some room for extra quick effect
controls. OR BETTER YET, bury the Mastering parameters into the
screen and use the knobs for effects. What the hell do we need fast
and furious access to the mastering compressor for instead of the
ability to turn up a delay return?? As I said, this box seems to
cast aside live use in order to highlight new "studio" features. As
far as I could tell, every singe customer who came up to me at Sam
Ash and asked me what I thought about the MC-909 was utterly
clueless and complete novices. I am sure that in the properly
coached salesperson's hands those mastering and random matrix one
knobs will sell a good many units. Thanks Roland. "What the
professionals asked for." It appears it may be what the professional
MBAs in accounting at Roland asked for. Despite it amazing features,
I may be much more forgiving of the word "toy" as used concerning
the MC-909 as opposed to the MC-505 for which I never thought that
term was justified. This all may seem harsh, and it is, but mainly I
am disappointed coming from a great respect for the MC-505 as a very
handy and fun tool. Roland has no one but itself to blame.
The use of the screen F buttons to choose the function of the mixer
sliders seems okay, but if you are not looking at the mixer screen,
which may be common during a live PA because you are looking at the
pattern select screens or something, then there is no way to know
(unless you remember) what the sliders are going to do if you move
them. To be sure, you must go back to the mixer screen (mercifully
you just hit the Mixer Assign button and see what they are set too.
This is where at least the dedicated side LEDs next the mixer
sliders on the MC505 would have been smartly retained. The inability
to use the sliders to tweak other than reverb is constantly
reinforced by the empty space above the F4 button. What, did they
run out of time to implement allowing to tweak say FX1? This is so
mental, and akin to a button that is there but has no function (I
would like to be able to say "yet," but I never say a new
functionality added on any roland gear I ever owned).
Recording: I spent the last 5 minutes trying to bang out a pattern.
I had no manual so it was hit and miss. It looks like the big screen
is put to good use to show what is happening with xox style
recording and step recording. The sequencing editing stuff looks
really good, just like a computer with the note tables and
microscope mode. Very nice.
But . . . so my baseline sucked. Quick add some Play Quantize. A
quick scan of the panel will show you that Play Quantize knobs are
gone. Okay look in the menues. Oops I can't find any! I can only
find the parameters for Edit-Quantize, which means that once you do
it, its done, no going back. The regular types, grid, swing and
groove templates.
But Geez! No Play Quantize? I sincerely hope I just couldn't find it
and it is there, and I realize now that I forgot to press that
button just to the right of the Screen entitled "Menu" (I have no
idea what it does). So I hope it is there! If Play Quantize (i.e.
one that you can try out and undo) is indeed missing from the MC-
909, then I must say that Roland is on drugs and I will be on a lot
of drugs before I ever buy it. Even if it is there, the fact that it
is so buried that I couldn't find it--instead of simply being on the
panel so nicely as on the MC-505-- is again, not live-friendly. I
must have missed it right? Someone with a unit please confirm! I
can't imagine not being able to smoothly add a small amount of swing
or groovequantise like on the 505, right? Forgive me if I missed it.
Filter: Sounds good and like the mc505 can be turned down internally
to not go the whole gambit from 0 to 127. I think it set to 115 but
still sounds pretty biting. I didn't try out the other filter types.
No negatives to report about the synth so far. I really did not
spend any time listening to sounds or presets. I assume they are
fine.
Some good things about the screen: The effects for Step filter and
the slicer use the the mixer sliders to set the steps and levels of
each step and you can see it right there on the screen that is
pretty cool. Well I joked about porn on the mc909 in the early days
of speculation but it is possible. You can upload your own bmp files
for the background picture and I bet one of ten screen savers will
utilize your bmp images. Looking forward to some interesting
pictures of your mc-909 guys . . . (but its not a toy!)
I don't really love the screen all that much though. It is so big
that it seems that no particular lcd setting will give you a
perfectly clear picture throughout and I shudder to think about the
screen fading in years. But as you can see this is the least of my
problems.
I think that is about it. Despite my rants, I am not totally sure
that I won't get one, but it will have to be a pretty good deal
(hint hint my friends at music stores). Even then, I don't know why
I need it. And I am certain that the MC-505 is a better live machine
(not including sample manipulation). I think that unless you will be
using samples in big way and want to be able to improvise with a
live band using such samples, then the 505 is a better tool. I
*would* actually enjoy building an arsenal of samples and being able
to use them whereever, whenever, with no click track in live
settings with the 909. This is the biggest reason for me to get one
if I ever do. In the studio, I don't need it whatsoever with my
computer, XL7 and ton of synths. I think I must keep my MC-505 after
all.
Summary: In the end my short visit with the MC-909 leaves me much
where I was when I found out the details of the specs: Scratching my
head at the choices made by Roland. I some ways this box is not the
evolution of the groovebox but is more Roland's answer to the MPC's.
Knowing first-hand the awesome strengths of both the MC-505 and the
MC-909 and also seeing the design choices made in the 909 that don't
retain the features or usefulness of the 505 seemingly just to be
different (i.e. all the reliance on the screen) or to highlight new
features (mastering effects knobs) it just seems so sad. It is as if
those who designed the MC-303 and the MC-505 did not work on the MC-
909 at all; and those who did, never really played the 505 or
understood its importance as a live tool as part of its allure. Pity.
Value: If the Command Stations are going for $699, then the MC909
should be $1099 max.
If the Command Station O.S. 2.0 adds some wild new features, the
Command Stations will be the new kings despite the lack of sampler.
For me, I am finding a new interest in my Yamaha A5000 which I
bought as a companion to my existing grooveboxes.
Hope you found this helpful. My apologies for completely forgetting
to find out what the hell "Matrix Control 1," "Random Modify" and
the "Fat" buttons do (something tells me they don't tweak effects or
quantise functions). Comments please.
Ravi
