Jumpy numbers
Jumpy numbers
2002-12-07 by Bill Kocher <billyk@insightbb.com>
The numbers on my main screen wether its presets or patterns jump
around when I am using the dial. It will jump back numbers. Then I
have to slow down to a really slow speed to get to where I am going.
Do I have to recalibrate. I did get a couple expansion roms?
Re: [xl7] Jumpy numbers
2002-12-08 by David DeciBel
I am having the same problem.  I think I will try Some TV TUNER cleanning
solution . .   Or maybe RuBBING ALCOHOL - ANY THOUGHTS?
To: <xl7@yahoogroups.com>
Sent: Saturday, December 07, 2002 5:17 PM
Subject: [xl7] Jumpy numbers
Re: Jumpy numbers
2002-12-10 by Bill Kocher <billyk@insightbb.com>
I think in started happening after I started adding roms. I think
recalibrating is the key.
cleanning
> From: <billyk@i...>
I
going.
Re: [xl7] Re: Jumpy numbers
2002-12-11 by David DeciBel
Not mine...It's been doing it for about 4 months now..   I'm bringing it in
tomorrow...
Sent: Tuesday, December 10, 2002 5:03 PM
Subject: [xl7] Re: Jumpy numbers
> cleanning
> > From: <billyk@i...>
> I
> going.
Re: Jumpy numbers
2002-12-11 by nifflas <nifflas@musician.org>
I suspect this is a very common problem with the XX-7's , my last XL-
7 did it, I sent it in and they repleaced it with a new XL-7. After a
couple of months my new machine started to do it again.
Might be some problems about the XX-7 hardware itself. Also, some
buttons is getting bad. When I buy the MC-909, I will use the XL-7 as
sound module only, then I will not suffer much from the weird data
wheel and buttons.
//Nifflas
bringing it in
> tomorrow...
> From: <billyk@i...>
> > cleanning
> > > From: <billyk@i...>
jump
Then
> > I
> > going.
Re: Jumpy numbers
2002-12-11 by alvinenglish <alvin.english@eudoramail.c
I had the jumping numbers a couple of times, but it went away after
rebooting the MP-7.  I can't readily duplicate the problem.  I assume
it is an operating system issue -- maybe it will go away in the next
version.
     Alvin
bringing it in
> tomorrow...
> From: <billyk@i...>
> > cleanning
> > > From: <billyk@i...>
> > I
> > going.
Re: Jumpy numbers
2002-12-11 by M2 <mmcquay@suscom.net>
Billy,
Here was a message in the archives from September.
Date:  Sun Sep 8, 2002  3:31 pm
Subject:  Re: My XL-7 is getting weird...
Nifflas,
There is a device connected to the data wheel called an encoder.
That is what's going bad. What I do on mine is to apply slight
pressure on the indentation(on the wheel)while turning in either
direction. That eliminates the jumping for me.
Later,
M2
--- In xl7@yahoogroups.com, "nifflas <nifflas@m...>" <nifflas@m...>
XL-
After a
as
> wheel and buttons.
> //Nifflas
> bringing it in
> > tomorrow...
> > From: <billyk@i...>
think
TUNER
> > > cleanning
> > > > From: <billyk@i...>
patterns
> jump
numbers.
> Then
> > > I
am
> > > going.
roms?
Re: Jumpy numbers
Alvin,
It is not an OS issue, it is the encoder.  Refer to the message that
was posted earlier.......
http://groups.yahoo.com/group/xl7/message/5698
--- In xl7@yahoogroups.com, "alvinenglish <alvin.english@e...>"
assume
> version.
>      Alvin
> bringing it in
> > tomorrow...
> > From: <billyk@i...>
think
TUNER
> > > cleanning
> > > > From: <billyk@i...>
patterns jump
Then
> > > I
am
> > > going.
Re: Jumpy numbers
M2,
    I see your point.  I have a different problem with the system.
--- In xl7@yahoogroups.com, "M2 <mmcquay@s...>" <mmcquay@s...> wrote:
> Alvin,
> assume
> > version.
> >      Alvin
> > bringing it in
> > > tomorrow...
> > > From: <billyk@i...>
> think
> TUNER
> > > > cleanning
> > > > > From: <billyk@i...>
> patterns jump
> Then
> > > > I
> am
> > > > going.
2002-12-12 by David DeciBel
I have the fortunate convenience of having a good friend that happens to be
one of the best techs in the midwest.  he looked at the encoder and jiggled
it and said "looks like a piece of crap encoder..." - he said that basically
it's cheaply made and so on.  We sprayed some sort of lube on it which
didn't really help.  Now I don't know if he's just kinda second guessing or
what, but I would like to get this fixed...  My unit is no longer under
waranty.  Anyone know of a way to get a better quality encoder?  EMU peeps?
I wouldn't want to replace it knowing that it might go out again in 6
months...
Thanks...  Everything else is great...
Sent: Wednesday, December 11, 2002 10:25 AM
> Alvin,
> assume
> > version.
> >      Alvin
> > bringing it in
> > > tomorrow...
> > > From: <billyk@i...>
> think
> TUNER
> > > > cleanning
> > > > > From: <billyk@i...>
> patterns jump
> Then
> > > > I
> am
> > > > going.
Re: Jumpy numbers
2002-12-12 by gongvibe <edmann@paiste.com>
Friends -
for the record (at least from my experience) the jumpy numbers thing is
the wheel/encoder, not the OS. I had those replaced on my P2k and E4 -
however - that was only after several years of heavy use. Not so bad
really. Mechanical stuff wears out. Get it replaced and you should have
no problems for a long time.
However - this is the reason that I harp on the playpads-as-numeric-
keypad OS option = an alternative way of entering values if the wheel
goes down.
peace and goodwill
gv
> months...
Re: Jumpy numbers
2002-12-12 by nifflas <nifflas@musician.org>
goes down.
An alternative way of entering values would be [---------THIS---------
] important for me, because my data wheel is really bad right now!!
Please include this in the next OS!
//Nifflas
2002-12-12 by erik_magrini@Baxter.com
I know what you're referring to with your idea, and think its a good one.
Keep in mind though that the key pads already to work as an alpha-numeric
entry method when you are in any naming field.   Use the transpose buttons
to access more numbers and letters.
Just a heads up for those that may bot have realized this.
goes down.
Re: Jumpy numbers
Thanks rEalm -
but again just to be clear (even for my own understanding) the function
that you refer to is for naming only - the alphnumeric keypad thing as
it is currently employed will not work for entering parameter values.(?
correct?)
I would love to see this: hitting 2 buttons (tba - for ex. Track/enable
+ Preset or?) simultaneously changes playpads C - A to 0-9; A# is (-);
B is (+) and high C is ENTER - which also functions as EXIT
alphanumeric mode and return to playpad mode.
The E4 has the backup option of being able to plug in a QWERTY keyboard
as an alternative to the wheel. But the Command stations have those
great pads just waiting to be fully exploited.
Just a thought - but a lifesaver if the wheel goes down at the wrong
time - and a much easier way of switching patterns for live use (you
come to understand intuitively that (C-E-E + hi C) means "044" etc.
But hey I am not complaining - I LOVE the XL7 it is a killer machine
that I am sure will continue to improve with time.
gv
> rEalm
> goes down.
