Actually, I think you need to use a computer-based MIDI sequencer to
load those guys up. The presets are coded differently than pattens
you can load with E-Loader in that most of the information is SysEx
data. To load the patterns you need to start a new MIDI track in you
sequencer of choice (Cubase, Sonar, etc...), be sure that the MIDI
channel on that track is going to the XL-7 and just press play. Be
warned that this will overwrite any presets that you already have
loaded on the 512 user preset locations. Repeat this for all 4 MIDI
files you get (one for each preset bank) and there ya go.
sapo
--- In xl7@yahoogroups.com, heyrag@n... wrote:
> You may need to delete your present files and download presets again
(assuming "open with" has been assigned to winplayer for some unknown
reason) You need to have Eloader (latest version from EMU) then open
those files again with eloader running, must have midi in and midi
out connected to your comp and box, once this is done use eloader to
send presets to mp7/xl7, I don't think you need to set mp7 to any
thing special as long as midi cables are connected.
