Sequencer timing: here comes the science
2002-12-06 by Nick Rothwell
In response to numerous comments about how tight the sequencer timing
is on the XL/MP, here are some concrete timings. Executive summary:
the timing accuracy varies from superb to unusable, depending on
circumstances.
The first set of drift timings are using a track pattern of 16th
notes, running at 125bpm. There is *no* MIDI output - all tracks
are set to "int". (oh: OS version 1.32.)
* Empty pattern, apart from the test track: drift of around 2msec.
* Factory pattern (Arctic Drift, in fact), tracks 1-15 muted, track
16 as test track: drift of around 3msec.
* Factory pattern, tracks 1-15 running with volume=0, track 16 as
test track: drift routinely at 10msec, worst case around 24msec.
* Factory pattern, test track on track 1, other tracks running with
volume=0: drift around 2msec.
SUMMARY: best-case scenario has sequencer timing within 2msec, which
is pretty hot. Data in other tracks doesn't influence performance if
the tracks are muted. (I have a feeling this wasn't true of OS 1.31,
but could be wrong.) With lots of tracks running, the timing of
high-numbered tracks is pretty dreadful, but low-numbered tracks are
prioritised and tight. So: keep the timing-critical tracks near the
top (top 6 if possible; from T8/T9 onwards the slop is audible).
A second set of timings tests the arpeggiator: this time, the sequence
is four quarter-notes (300 ticks long), but the preset repeats at 1/16
notes.
* Test pattern only: drift < 2msec.
* Test pattern as track 16, others muted: < 2msec.
* Test pattern as track 16, others running volume=0: routinely 8msec,
often around 15msec.
* Test pattern as track 1, others running volume=0: routinely 8msec,
SUMMARY: in ideal circumstances (sparse data), the arpeggiator has
slightly better timing than the sequencer, but it degrades equally
badly when other tracks are active, and -- curiously -- lower-numbered
tracks are apparently *NOT* prioritised, so there's no clear way of
improving critical arpeggiator timing in a busy pattern.
I've not done any timing tests of the internal clock-based modulation
architecture; I guess that would be next. I can live with the
sequencer timing since it's clear how to keep it tight; the
degradation of the arpeggiator timing is worrying. (I've also had more
serious problems with arpeggiator drift which I plan to track down.)
Interestingly, turning MIDI on for the tracks ("ext"/"both") doesn't
seem to make much difference. The XL-7 seems to have
bandwidth/performance issues internally, regardless of the external
MIDI traffic.
A note on the timing procedure: I just let the XL-7 freewheel,
recording the test patterns into Digital Performer (also freewheeling,
using a Korg OasysPCI as clock source). Each measurement is done with
a single 30-second recording of the ticks displayed on two tracks, one
of them offset by visual inspection by a whole number of
16th-notes. The drift can be seen visually by comparing events on the
two tracks, and the sample offsets can be read off by inspection (and
then divided by 44.1).
Any comments?
nick rothwell -- composition, systems, performance -- http://www.cassiel.com
