New Features
2001-10-30 by Sean Wilhelmsen
Projected 1.17 Feature List For XL/MP-7 Command Stations Due out = Mid to Late November Song and Pattern Event Editor w/ delete and insert (Transpose, Tempo, Program changes, Bank Select, Pitch, Controllers) Song and Pattern Note Editor w/ delete and insert (Velocity and Duration) Key range editing for most edit functions (Quantize, Transpose, Duration, Erase, Thin) Duration Offset/Scale Measure ranges for Cut, Copy, Paste Local On/Off Key Pad Transpose (Semitone added) Routable MIDI Input - A or B channels Improved UI and transitions when selecting patterns while playing Improved UI track selection when editing patterns More Resolution for Step Record Re-channelization of incoming MIDI data option Revert to saved Pattern USB Pattern and Song Upload/Download from your computer using E-Loader I thought I'd give you the skinny on what we are working on for you. Legal - List subject to change or be added too - sean at e-mu / ensoniq BTW: Key Maps for all of our ROMS will be on our web site by the end of the week.
