Archive for xl7.
Re: Q (was "anyone?")
2001-10-30 by Aaron Eppolito
Resonance or Q is a note-on parameter only.  If you notice in the patchcords
section, 'FiltRes has an apostrophe before the name, which is the universal
symbol for "note-on only".  It is not a bug, but rather the hardware design.
This comes up about monthly on the various lists.
With some creative programming, however, you *can* do some realtime "Q"
effects.  I'll see if I can dig up the patch that I did a while back and I'll
try to post it to the files section tomorrow.
-Aaron
PS. by the way, every now and again, I do like to write code as opposed to
list posts... =)
mikexl7@... wrote:
> I am at a total loss here.  there must be someone that has had the
> same problem out there.  I am a little conserned considering that
> aron from emu has passed by and not touched on this one.  If anyone
> has any ideas please feel free to contact me directly, or just post.
> thanks again
> Mike
> "Another thing i am noticing that i dont know how to fix is....
>  When i use the defaullt preset to make my own instrament when i use
>  the Filter Q quick edit knob it dose not change the sound till the
>  next note is played rendering it usless when i need it most.  I use
>  it most often to thin out a fat leed or pad wile holding down a
> chord
>  or note.  How do i change this?  anyone know what i am talking about
>  here?"
2001-10-30 by mikexl7@yahoo.com
Thank you both for getting back to me on this one i appreciate it.
First off thanks aron for mentioning that the apostrophe simbolizes
the note on thing i had no idea that that was the case.
And as for creative programing i am up to it and would love to know
how you worked this out!
oh ya is there a resource for learning about programing with emu
patch chord system?
I would love to read what people who have a better understanding than
myself are dooing with this form of modern modular synthasizer.  I
consider myself to be above biginer but am yet to be a master and
would love to increase the speed of my learning in this area of my
music making.
thanks
Mike
patchcords
universal
hardware design.
realtime "Q"
back and I'll
> -Aaron
opposed to
> list posts... =)
2001-10-30 by bruce@sigalarm.com
Shows you what can happen if you leave your XL-7's Arpeggiator on all
the time.  Emu folks, this is a throw back to the E-Chip that did that
filters in the Morpheus (many moons ago). You still don't have that
working? (Real time resonance on a filter).  I had assumed that the
reason that all of the modules and samplers since that groundbreaking
instrument had implemented a weaker filter suite was to overcome that
limitation.
Wow.
That being said, I do just run either a patter or an arp all the time,
and I seem to be able to get things tweaky.  So it's a deficiency that
can be tough to spot.
Bruce
patchcords
universal
design.
"Q"
and I'll
> -Aaron
opposed to
> list posts... =)
anyone
post.
> > thanks again
> > Mike
use
use
> > chord
about
> >  here?"
> > xl7-unsubscribe@y...
2001-10-31 by mikexl7@yahoo.com
ya Bruce this is kinda lame indeed. When using many of the presets
this feature seems to be working fine but i haven't done the digging
to see how they got around it yet.
I own an E5000 and it works fine in this respect so i dont know why
it is the case with the synth inside the XL-7.
What is up with that?
I don't understand why some of the instraments of the modern age are
dumping some of the sound sculpting tools and abilities of the synths
of old.  It seems odd to me, like if the thing can handle 128 notes
there must be the power under the hood to have the filter sweepable.
I am not a code wrighter so i cant say that i know how thies things
are made today but this is just a general comment on how electronic
instraments are changing.
The bottom line is i am just glad that the E5000 is in my rack and
the filters in it don't work the same way as the XL-7's
all
that
groundbreaking
that
> limitation.
> Wow.
time,
that
> Bruce
> patchcords
> universal
hardware
> design.
realtime
> "Q"
back
> and I'll
> > -Aaron
> opposed to
> > list posts... =)
that
> anyone
> post.
> > > thanks again
> > > Mike
i
> use
> the
I
> use
> > > chord
> about
> > >  here?"
2001-11-01 by drk@delora.com
Well Emu can certainly defend themselves, but it may be helpful
to understand that the filters Emu uses were(are?) quite
innovative for digital filters, though when compared against
today's world of VA type filters they seem inadequate.  What Emu
"invented" with the Morpheus concept was the ability to make a
filter that could be changed from one type to another in real-time.
So you could have some pretty twisted filtering characteristics,
far beyond the tradition sweep the cutoff frequency limitation.
But this approach to filter implimentation has a limit in that only
one parameter can be varied in realtime.  Now this parameter
can cause quite complex things, including changing multiple
traditional filter parameters - things like sweepin frequency while
changing bnandwidth.  But you only get to "morph" in one
dimension at a time.  So a tradition synth filter, like a 4 pole
lowpass can have real time adjust of cutoff but not resonance.
The work around is that in an instrument like the P2K
architecture, since it supports truly dynamic voice allocation and
is multitimbral, you can switch filter types on the fly from note to
note.  So to change Q is really replacing one filter with a slight
variation with the Q increased or decreased.  This is why
resonance is usually a note-time only adjustment.  I do seem to
recall at some point either my Audity 2K or Ultra having a filter
where Q was not fixed at note time, but I could be mistaken.
BTW, the above explaination is what I have sussed out of the
Emu information and products I have owned over the years.  So it
could be incorrect, especially in the details.  But this is my
understanding of why the filters are as they are.
Should Emu change this?  That's another question entirely.  Its a
tradeoff really.  Is it better to have a few traditional filters that
behave "normal", or to have the flexibility of filter types.  Also, Emu
has quite a few morphing filters in their archives.  They could
well add new ones to the XL7/MP7.
Which leads me to a question: why isn't the famous "BatPhaser"
filter in the XL7/MP7?
drK
Re: [xl7] Re: Q (was "anyone?")
2001-11-01 by Aaron Eppolito
You're exactly right with everything you've said.  I promised that I'd get
you a preset that emulates realtime Q, and I found what I think is a sysex
dump of it, but can't quite seem to get it to work.  I'll try and recreate
it...
-Aaron
PS.  I think "BlissBatz" is the same as BatPhaser?
> drK
2001-11-02 by bruce@sigalarm.com
<ramble>
They were quite groundbreaking back in the early 90's when they came
out.  But as I have mentioned, even my new ultra powerful XL-7 with
its nice CPU cannot do all of the filter types that my Morpheus can.
Many folks say so what, and they are welcome to that.  But some of the
stranger filter types are really interesting.  I still think the
Morpheus is the best module for making spacey / ambient music ever.
(your milage may vary).
As far as real time Q on Z Plane type filters,  just because they
can't do it does not mean it can't be done.  Computationally it could
be a problem, but it should be possible.  There is no reason from a
mathematical standpoint to not be able to modify multiple axies (sp?)
of a Z plane filter at the same time, but it would take a bunch of CPU
and memory.  But then again take a look at what we can do now with
MP3, and imagine trying to implement that 15 years ago.
Anyhow, just armchair DSP quarterbacking on my part.  I still love my
Emu stuff.  Would not give it up for anything.  It takes its place
rightfully with some of the best of my rig.
Oh yeah, one of the greatest combos I have yet to enjoy is a Korg Z1's
X/Y touchpad linked to Z Plane filters, again the Morph kicks
everyone's butt here.
</ramble>
Bruce
> drK
