To: <xl7@yahoogroups.com>
Sent: Sunday, November 17, 2002 11:16 PM
Subject: Re: [xl7] Re: COMPACTING? ERROR SAVING?
> Exactly. It's not an error, just an informational prompt. As the
> system writes data, it eventually needs to "defragment" flash memory.
> This usually takes most users many months to occur. You can't do it
> manually. The only reason it gives you a prompt at all is because it
> takes the sequencer offline. If you get it and need to keep
> performing, you can just cancel the prompt, but you won't be able to
> save until you allow it to compact.
> -Aaron
> --- M2 <mmcquay@...> wrote:
> > A compacting prompt is sort of like an automatic backup, it depends
> > on how much you use the machine and also how often you save data.
> > --- In xl7@y..., "David Jones" <spec@s...> wrote:
> > > I just ran across an error (forgot to record it) but it said my
> > > pattern could not be saved. Last I checked I had 67% memory left.
> > > Then it asks if I want to compact data. This isn't in the manual,
> > > but should I be "compacting" more often?
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Web Hosting - Let the expert host your site
> http://webhosting.yahoo.com
