Proteus 2000 and MP-7
2002-11-15 by kacy.rayburn@kmzr.com
Is there a way to Sequence from the Proteus 2000 into the MP-7?
I want to be able to have the Proteus 2000 Midi notes sequenced into the
MP-7. i.e.,:
Track/Channel 1: MP-7 Drum Kit
Track/Channel 2: Proteus 2000 bass
Important:
This electronic mail message and any attached files contain information
intended for the exclusive use of the individual or entity to whom it is
addressed and may contain information that is proprietary, privileged,
confidential and/or exempt from disclosure under applicable law.  If you
are not the intended recipient, you are hereby notified that any viewing,
copying, disclosure or distribution of this information may be subject to
legal restriction or sanction.  Please notify the sender, by electronic
mail or telephone, of any unintended recipients and delete the original
message without making any copies.
Re: Proteus 2000 and MP-7
2002-11-15 by M2
No, you would just play the notes on the MP-7 pads(or external
controller) and set the tracks you want the P2K to play to
external.  Set up your P2K with the patches that you want and save
them as a multisetup.  Make sure that the tracks(on the P2K)that you
don't want to play, are turned off or make sure that the MP-7 is not
going to send midi data to those channels.
Later,
M2
into the
> MP-7. i.e.,:
> Important:
information
it is
privileged,
If you
viewing,
subject to
electronic
original
Re: [xl7] Proteus 2000 and MP-7
2002-11-15 by drK
> MP-7. i.e.,:
Not sure what exactly your trying to accomplish here.  And you do mean the
Proteus 2000 and not the Proteus 2500?  The Proteus 2000 does not have a
sequencer in it, unless you mean the Audition riff or possibly the
arpeggiator.
If what you mean is you want to use the Proteus 2000 as a sound module for a
MP7 track, then that's pretty straight forward.  We'll use your example.
Choose the pattern you want to work with and select track 1 using the
TRACK/CH buttons.  Now enter the EDIT PATTERN menu and scroll until almost
the very end where you will see CHANNEL ASSIGN.  Set this to
  Channel: 01A  Dest: int
Next hit the TRACK/CH "+" button to go to the next track (track 2) and set
the CHANNEL ASSIGN to:
  Channel: 02A  Dest: ext
Make sure your P2K is connected to the MIDI-A output.
At this point you're ready to work with the MP7's internal sounds on track 1
and the Proteus 2K's sounds on track 2.  Select the desired preset on both
instruments for the respective channels.  In this case the MP7 would have
channel 01A set to your drum kit choice and on the P2K channel 02A would
have its preset set to the bass sound you want to use.  if you set the
Proteus 2K from its front panel you will be able to use the category browse
feature.  You will also need to disable receiving program change in the P2K
on the edit page RECEIVE PROGRAM CHANGE.  Set this to off for any channels
you are controlling with the MP7 otherwise it's patch change commands will
override what you set on the P2K.
Alternatively you can set the desired preset in the MP7 by placing a program
change command at the beginning of the track.  this though requires using
the editing features to insert the command and setting the preset by number.
You can use the above method to have any number of tracks assigned to
combinations of internal MP7 sounds or Proteus 2K sounds.
I hope this is what you were after.  If not please try again and clarify a
little more.
drk
www.delora.com/music
www.mp3.com/zdrk
drk.iuma.com
Thanks you all, I truly appreciate the help I 've received from you all.
                    drK
                    <drk@...       To:     "xl7@yahoogroups.com"
                    m>                    <xl7@yahoogroups.com>
                                         cc:
                    11/15/2002           Subject:     Re: [xl7] Proteus 2000 and MP-7
                    12:55 PM
                    Please respond
                    to xl7
> MP-7. i.e.,:
arpeggiator.
a
1
program
number.
little more.
drk
www.mp3.com/zdrk
drk.iuma.com
Important:
