S/PDIF Output level
S/PDIF Output level
2002-11-15 by gongvibe
Greetings Posters -
As mentioned previously, and as many of us know, the level of the
digital output from the e-mu modular line is low, to allow for extremes
that may occur with regard to extreme patch resonance etc (this is my
impression, tell me if I am wrong)
In that the level of a digital signal has direct correspondence with
bit resolution, does that mean that the base-line low level digital
signal is less than 16 bits - i.e. like 8-12 bits?
just curious, technically I think this would make sense
I never use the digital output - but I would like to
does anyone out there use it?
thanks!
g-vib
Re: [xl7] S/PDIF Output level
2002-11-15 by erik_magrini@Baxter.com
As mentioned previously, and as many of us know, the level of the digital
output from the e-mu modular line is low, to allow for extremes that may
occur with regard to extreme patch resonance etc (this is my impression,
>>>Yeah, I think this was the answer we were given before. <<<
In that the level of a digital signal has direct correspondence with bit
resolution, does that mean that the base-line low level digital signal is
>>>Yep, that's my guess too.  Bummer, but at least you can normalize and
not worry about background noise, so it could be worse I suppose. <<<
I never use the digital output - but I would like to does anyone out there
use it?
>>>I do/did when I record the XL-7 into Cubase SX.  Unfortunately my
digital cable no longer works, so I need to buy a new one. <<<
Re: S/PDIF Output level
> In that the level of a digital signal has direct correspondence with bit resolution, does that mean that the base-line low level digital signal is  less than 16 bits - i.e. like 8-12 bits?
> >>>Yep, that's my guess too.  Bummer, but at least you can normalize and  not worry about background noise, so it could be worse I suppose.
***still - to my way of thinking this means that one would be better
off to record the loudest analog signal possible than to use the
digital output. I would rather have a 15- 23 bit recording from an
analog source than a normalized version of 10 bit digital source. I
have tried both methods, and have noticed that the analog-source
recordings sound brighter and sharper.***
gvibe
2002-11-15 by jesse_medway
Exactly, normalization doesnt improve the quality at
all.  Yes it makes it louder but its just a louder
version of that 10 bit signal.
I checked the specs though and although the samples
are in 16bit format it says the outputs are 20bit.
The effects are 24 bit.  It doesnt really say what
the actually mix buss is at though.  But if the outputs
are 20bit at the spdif then you would be ok to have
a conservstive level.  6db drops you 1 bit so even 12db
below 0 would still be 18bit.
Maybe someone from Emu can clarify.
Jesse
> gvibe
2002-11-16 by freakyfreq
I believe you're right! The outputs of the S/PDIF are a 20 bit word
and the effects are processed at a 24 bit rate. I read earlier,
someone was recording at 24 bit to get the full resolution, which is
fine once you dither it down. Technically, S/PDIF can only transmit
up to a 20 bit word length anyway!
Oh yes, almost forgot! There is a CD player which will play a CD-R at
24 bit/96k. It's the Alesis MasterLink. These CD-R's will not play in
a regular CD player though, only on the MasterLink.
> Jesse
an
I
> > gvibe
2002-11-16 by jesse_medway
Not ture.  SPDIF normally carries 20bits of audio and
another 4 bits for status info.  But if programmed to
it can pass a full 24 bits of audio by leaving out
any status messages.
