Questions (emu techs, who ever..)
2002-11-14 by erik_magrini@Baxter.com
A couple questions for the Emu techs: - Can you let us know exactly what parameters are being affected by the Randomize Preset function? I know that none of the pitch settings seem to be changed, what other one's don't get randomized? Will randomize assign waveforms from more than one ROM? - Sometimes when you're in Song Mode, it's neccesary to jump back to Pattern mode to do a quick edit to the currently playing Pattern (at that step in the song). Easy enough. However, sometimes when you go back to Song Mode, the current pattern for that step will loop once, instead of switching to the next pattern when it's done playing (ie, the next one assigned to the following Song Step). Is this normal, or a bug? - Weirdness. Scrolling in the Event List Editor, and you are holding down ENTER while the cursor is under the value for the controller you're trying to edit. Obviously this lets you keep the cursor in the field where you want it, so that you can change values for multiple events without having to keep pressing the left/right keys to get to that field. However, everytime you do this and you pass a different controller type, the cursor jumps back to the first field, and does not the remain where you want it. IE, I'm trying to lower all CC#7 values recorded in a pattern by a few numbers. So I place the cursor under the field for the first CC#7 amount value, change the number, then hold down Enter and scroll to get to the next CC#7 value. So far so good. However, if while scrolling I pass say a Pitchbend event, the cursor now automatically moves back to the very first field in the Event List Screen. Bug or intentional? rEalm [Non-text portions of this message have been removed]
