Ah yes, the all elusive enigma of the multi-setup....it does it to me
too...I thought I had it working at one point (ie, patches would be saved to
there respctive tracks on seperate patterns, differeing from one pattern to
the next) But perhaps I had had a bit to much of the halfling's leaf at that
time, because it dosnt seem to work anymore. If this is an 'intentional'
issue, as in, it suppossed to work like that, I hope it's something that's
taken care of in OS2, because it literally keeps me from using any of the
internal sounds all together, it gets way to frustrating. Until then, I'm
sticking with my external gear. I had even started working on a track for
the 'contest', but ended up giving up in a frustrated rage, since every time
I would start the beast back up, I would have different sounds loaded into
my tracks! ARG!
ByronIV
> -----Original Message-----
> From: pocketd@... [mailto:pocketd@...]
> Sent: Saturday, November 30, 2002 12:42 PM
> To: xl7@yahoogroups.com
> Subject: [xl7] multisetups
> Hi,
> there\ufffds something about multisetups I still don`t understand:
> a multisetup is a group of parameters depending on the sound
> settings of the
> internal module, so
> for every pattern, or say for the next song you should have an own
> multisetup to setup all the 32
> channels, menues etc., right?
> Multisetups change the Presets, Global etc. for every pattern on
> my XX-7, is
> that normal?
> I don\ufffdt believe it\ufffds normal, cause if I restore the factory
> setup, there are
> lot of different
> configurations for all my patterns.
> So, I read there\ufffds a way to setup a multisetup via midi or in
> songmode, do u
> do it this way?
> Do u save both multisetups and patterns, whenever you change in
> one of there
> menues.
> Well,
> I hope never to talk about that setups again,
> Chri
> Neu: Finanz-Fakten testen jetzt um 35% billiger + ein Geschenk
> Ihrer Wahl!!
> http://bonus.gmx.net/?gid=41442879&prid=688
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.406 / Virus Database: 229 - Release Date: 10/21/2002
Outgoing mail is certified Virus Free.
