Knob ranges?
2001-10-23 by erik_magrini@Baxter.com
Hey guys, does moving a controller knob on the XL-7 cause the sound to jump to the new setting of the knob? For example, if I select a new pattern, and turn the cutoff knob on a Preset, will the cutoff value jump to the closet knob value the second I turn it? Or do I have to turn the knob past the Preset's default setting before the new changes are heard? Hopefully this is a bit more clear than yesterday pre-coffee shot at asking the same question :) Also, just to clarify, the USB port isn't implemented at all right now correct? All OS changes need to be done via E-Loader and the Midi port? Are there plans for the USB functions in the near future? I'm picking up my XL-7 tonight hopefully, so I just wanted to clarify some things before I load the new 1.01 OS after I get it... Thanx! rEalm
