Hi there yall
Im trying to control my Akai S3000 XL Via Mp-7 like i control the
rest of my gear (prog changes, notes etc..) but it isnt not receiving
any midi signal from the mp7 - !
all other gear connected via ext-out a&b is working well, even those
which go through the s3000xl .
Kindly advice
apreciate your prompt reply..
If You Know your Midi You'll Solve your Proble by Cheching Your Midi setting
On your MP7 And You Should Check Your Master Setting. But I Have A MPC 2000
& I use As A Master Because It's True. The MPC is a Midi Controler
