How many edit buffers?
2001-10-17 by drk@delora.com
OK, there is a couple of ways to implement a multi-timbral mode in a synth, and I am wondering what the XL-7 does. The first (and my desired) way is to have an independent edit buffer for each instrument (channel, or part in some terminology). This lets you do patch edits on the fly, while sequencing and have those edits remain in effect until you change patches on an instrument. The second way is to have a single instrument edit buffer. In this approach any changes made to a patch are lost when you switch to a second instrument to edit. I am concerned that the XL-7 has method two - a common edit buffer for all channels. The reason for the concern is that the Audity 2K module I have (which has the 2.01 firmware, which makes it pretty much in line with the rest of the P2K family) impliments method two, the shared edit buffer. Can anyone answer this? Thanks in advance, drK
