Fisrt THANK YOU to all for quick respond YOU ARE COOL but...
2002-10-11 by pawelmr
FIRST YOU ARE ALL COOL !!!!!!!! THANKS BUT ::: I can play presets means rom is installed corectlly PROBLEMS is with PATTERNS form MP7 when I loaded using either cubase or emu loader pattern and play and preset keep saying NOT INSTALLED HEEEEEEEELP before I smashed this BABY :) PEACE ALL
2002-10-11 by Greg Oler
Check to make sure you have a midi signal. Try a re-sync with the e-Loader. I get that message when there is no chatter between the PC and the XX7. -greg --- pawelmr <noxen@...> wrote: > FIRST YOU ARE ALL COOL !!!!!!!! THANKS BUT ::: > I can play presets means rom is installed corectlly > PROBLEMS is with PATTERNS form MP7 when I loaded > using either > cubase or emu loader pattern and play and preset > keep saying NOT > INSTALLED HEEEEEEEELP before I smashed this BABY :) > PEACE ALL > > > > > ------------------------ Yahoo! Groups Sponsor > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > __________________________________________________ Do you Yahoo!? Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com
2002-10-11 by Aaron Eppolito
The patterns are designed to select presets from the MP-7 ROM, not the Pure Phatt ROM. They have the same samples, but different presets and different IDs. The sequencer is trying to select a sound ROM you don't have. -Aaron --- pawelmr <noxen@...> wrote: > I can play presets means rom is installed corectlly > PROBLEMS is with PATTERNS form MP7 when I loaded using either > cubase or emu loader pattern and play and preset keep saying NOT > INSTALLED __________________________________________________ Do you Yahoo!? Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com
Greg I can load to any patterns but when I try to play nothing and when I go to to presets still massage NOT ONSTALED but i CAN SEE AND PLAY bts kits etc... but NOT PATTERNS --- In xl7@y..., Greg Oler <golerage@y...> wrote:
> Check to make sure you have a midi signal. Try a > re-sync with the e-Loader. I get that message when > there is no chatter between the PC and the XX7. > > -greg > > > --- pawelmr <noxen@h...> wrote: > > FIRST YOU ARE ALL COOL !!!!!!!! THANKS BUT ::: > > I can play presets means rom is installed corectlly > > PROBLEMS is with PATTERNS form MP7 when I loaded > > using either > > cubase or emu loader pattern and play and preset > > keep saying NOT > > INSTALLED HEEEEEEEELP before I smashed this BABY :) > > PEACE ALL > > > > > > > > > > ------------------------ Yahoo! Groups Sponsor > > > > To unsubscribe from this group, send an email to: > > xl7-unsubscribe@y... > > > > > > > > Your use of Yahoo! Groups is subject to > > http://docs.yahoo.com/info/terms/ > > > > > > > __________________________________________________ > Do you Yahoo!? > Faith Hill - Exclusive Performances, Videos & More > http://faith.yahoo.com
OK Aron got this but what I should do to be able play MP 7 patterns ? --- In xl7@y..., Aaron Eppolito <synthesis77@y...> wrote: > The patterns are designed to select presets from the MP-7 ROM, not the > Pure Phatt ROM. They have the same samples, but different presets and > different IDs. The sequencer is trying to select a sound ROM you don't
> have. > > -Aaron > > --- pawelmr <noxen@h...> wrote: > > I can play presets means rom is installed corectlly > > PROBLEMS is with PATTERNS form MP7 when I loaded using either > > cubase or emu loader pattern and play and preset keep saying NOT > > INSTALLED > > __________________________________________________ > Do you Yahoo!? > Faith Hill - Exclusive Performances, Videos & More > http://faith.yahoo.com
Sean's advice on contacting Emu' service department is your best bet. Sorry that I couldn't be more help. -Greg --- pawelmr <noxen@...> wrote: > Greg I can load to any patterns but when I try to > play nothing and > when I go to to presets still massage NOT ONSTALED > but i CAN SEE AND > PLAY bts kits etc... but NOT PATTERNS > --- In xl7@y..., Greg Oler <golerage@y...> wrote: > > Check to make sure you have a midi signal. Try a > > re-sync with the e-Loader. I get that message when > > there is no chatter between the PC and the XX7. > > > > -greg > > > > > > --- pawelmr <noxen@h...> wrote: > > > FIRST YOU ARE ALL COOL !!!!!!!! THANKS BUT ::: > > > I can play presets means rom is installed > corectlly > > > PROBLEMS is with PATTERNS form MP7 when I loaded > > > using either > > > cubase or emu loader pattern and play and preset > > > keep saying NOT > > > INSTALLED HEEEEEEEELP before I smashed this BABY > :) > > > PEACE ALL > > > > > > > > > > > > > > > ------------------------ Yahoo! Groups Sponsor > > > > > > To unsubscribe from this group, send an email > to: > > > xl7-unsubscribe@y... > > > > > > > > > > > > Your use of Yahoo! Groups is subject to > > > http://docs.yahoo.com/info/terms/ > > > > > > > > > > > > __________________________________________________ > > Do you Yahoo!? > > Faith Hill - Exclusive Performances, Videos & More > > http://faith.yahoo.com > > > ------------------------ Yahoo! Groups Sponsor > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > __________________________________________________ Do you Yahoo!? Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com
2002-10-11 by nodalterror
you can play the presets, you just have to mess around with the instruments. i am assuming you dloaded the mp-7 patterns into an xl-1... the sequencer info is there, so just swap out the "not loaded" instruments, with some that you have. it might not be the exact sound that emu had in mind when they wrote the preset, but you can get the basic groove and work it into something neat...
On Friday, October 11, 2002, at 12:32 PM, pawelmr wrote: > OK Aron got this but what I should do to be able play MP 7 patterns ? > > --- In xl7@y..., Aaron Eppolito <synthesis77@y...> wrote: >> The patterns are designed to select presets from the MP-7 ROM, not > the >> Pure Phatt ROM. They have the same samples, but different presets > and >> different IDs. The sequencer is trying to select a sound ROM you > don't >> have. >> >> -Aaron >> >> --- pawelmr <noxen@h...> wrote: >>> I can play presets means rom is installed corectlly >>> PROBLEMS is with PATTERNS form MP7 when I loaded using either >>> cubase or emu loader pattern and play and preset keep saying NOT >>> INSTALLED >> >> __________________________________________________ >> Do you Yahoo!? >> Faith Hill - Exclusive Performances, Videos & More >> http://faith.yahoo.com > > > ------------------------ Yahoo! Groups Sponsor > ---------------------~--> > 4 DVDs Free +s&p Join Now > http://us.click.yahoo.com/pt6YBB/NXiEAA/MVfIAA/pWZylB/TM > --------------------------------------------------------------------- > ~-> > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > >
