routing effects parameters to knob controllers
2002-10-08 by epvn896
hello again everyone,
i'm afraid i have a stumper this time. i looked all throughout my
manual but i still couldn't figure this one out.
is there a way to route the delay time to one of the knob controllers,
so that i can record realtime delay changes into my patterns?
thanks in advance,
-brian
Re: [xl7] routing effects parameters to knob controllers
2002-10-08 by Aaron Eppolito
> controllers, so that i can record realtime delay changes
> into my patterns?
Oddly enough, no.  I was sure you could but it's not available in the
patchbay.
Okay, I've thought about this for a while now, and think I might have a
solution (albeit a complicated one).  Here goes.  For all the preset
layers you want to change the timing on, do the following:
1 - Edit the Volume Envelope to be:
              Rate  Level
    Attack1:  0     1%
    Attack2:  0     0%
    Decay1:   X     100%  (X would be the "attack" time you wanted)
    (you can leave the rest alone)
2 - In the patchbay, hook up the following cord:
    VolEnv+ -> SRetrig  +001
Then, by changing the Amp Attack knob (Knob E), you should be able to
control that preset's delay.  I'm not sure this will work (haven't
tried it) but the concept is as follows:  Play the sound when
triggered, but keep the sound quiet until the desired time (by changing
the rate of the attack times) with the volume envelope.  Then, after
that time has passed, bring the volume envelope back up and also use it
to retrigger the sound (so that it starts from the beginning).
Let me know how it goes...
-Aaron
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
2002-10-09 by pocketd@gmx.de
i read following on a tips & tricks page (?), perhaps it helps:
LFO2+- -> SRetrig  -001
Aenv+- -> LFO 2 Rate  11-20% (Delay-time)
set Amp Env.Release to 1 till 50
LFO 2 rate to 0,08
Aux Env everything 0 except Rl2 level=100
I did test it once, and it did work, I´m not sure why Aaron uses the Amp
env, perhaps I didn´t
understand right what U wanted,
Cy,
Christoph
> into my patterns?
patchbay.
              Rate  Level
    Attack1:  0     1%
    Attack2:  0     0%
-Aaro
FÜR SIE - alles was moderne Frauen wissen möchten!
http://bonus.gmx.net/?gid=41442879&prid=85
