os suggestions
os suggestions
2002-10-04 by barleyqueen2001
the repeat button only works when you are recording, this is really
naff since you are not able to jam or practise with it before
recording. so the repeat function working in play mode would be
usefull , for me it is now useless.
the possibility to use user patterns is beats mode, i think now you
van only use preset beats, but using youyr own patterns as elements
in beats mode, would be really something not this karaoke function
that it is now.
drum kits programming in stead of 4 layers
the pos. to split a jammed one channel rhitmic pattern on 1 channel
*or 2* into hi hat kik snare etc...
good luck
